Idling issue
Old May 1, 2013 | 09:40 PM
884runner1021's Avatar
Idling issue
Hello, I have a 1988 4runner 22RE 5-speed. I did a motor swap and the donor vehicle was a 1995 2wd Toyota truck. I've got the 88' running but the idle is jumping from 100rpm to 600rpm and fuel is spraying out of the #1 injector. Immediately replaced the o-rings and the gaskets for all four injectors. problem remains and fuel is still spraying.
However, when I did the motor swap I am still using the intake plenum, injectors, distributor cap off the 88'. The entire bottom end is from the 95 with the exception of t oil pan and the oil pickup basically the only thing from the 95 motor is the block and the heads. any questions please ask, I will be having the injectors refurbished..thanks
Old May 5, 2013 | 03:15 PM
mitutoyo's Avatar
This may or may not be your issue but, I believe the 88 4runner uses low impedance fuel injectors and the 1995 uses high impedance. What year ECU are you using?
Old May 6, 2013 | 10:06 PM
it was a combination of things, changed my injectors and and the air box computer can't remember the name of it either way both came off the 95 22RE. The injectors i just modified the clip and it worked like a charm
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kyletbert
Jul 17, 2015 11:39 AM
