what is this 3.0 vacuum related ... by fuse relay block
Old May 3, 2013 | 09:40 AM
SeeBeeAre's Avatar
I have a code 25 26 and i ran propane around the vacume lines and it appears to have a vacuum leak at this part.... what is it what is the adjustment screw for the lines go under the plenum so its hard to say where they go
Old May 3, 2013 | 09:52 AM
scope103's Avatar
A/C Idle-up.
http://personal.utulsa.edu/~nathan-b...24vacuumsw.pdf
You need it (otherwise the A/C will kill the engine at idle), so you should find which of the several lines is actually leaking and fix it.
I'd start by tracing the small lines back to the plenum, then disconnect (from the tee toward the VSV) and plug (a golf tee is the traditional tool) the other end. This will isolate the actuation vacuum circuit from the idle-up circuit (large hoses). It will make it easier to decide which one is the problem. The vacuum line to the 3-port filter (on the plenum) is labelled #2.
Old May 3, 2013 | 10:11 AM
a51young's Avatar
I had a leak from my 'that thing' as well, looked like the connection for the lower vacuum line had a portion worn away from some other line around the area. Bought a new unit from ebay for something around 20
Old May 3, 2013 | 10:14 AM
Hugh_Mann's Avatar
Hah I was just looking at this the other day wondering what it was for. I'm always amazed at all the vacuum lines the 3.0 has...
Old May 3, 2013 | 10:17 AM
SeeBeeAre's Avatar
what does the screw do?
Old May 3, 2013 | 01:03 PM
YotaWoRx's Avatar
Idle adjustment when compressor is engaged
rushw
Jul 18, 2015 01:46 PM
Sandman
Jul 14, 2015 12:36 PM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
colinmil
Jul 6, 2015 04:03 PM
