- Looking for exhaust shop around Boulder CO
- Need rust help with my 4runner
- Need Advice on Winch Installation, Suspension, Bumper -- Thank You All
- Headlight Ground?
- I had a reality check today about my pickup...
- cant find a diff breather.
- toyota pickup offcamber pic
- 1990 Toyota 4x4 Idleing problem
- 22RE 1990 Toyota Fuel Injector Replace - Help
- 4runner shut off
- Manual hub removed&reinstalled-now LOCKED always!?
- 89 4Runner with really weak front heat, but blazing back heat. Why?
- buying another yota
- exhaust smell source
- Swap advice needed
- Sickest deal ever...
- I need help ready to give up. Carb questions.
- has anyone built their own center console? lets see them pics....
- cone filters vs airboxes (comparison with support)
- 3.0 Knock Sensor
- Look what came out of my fuel filter
- cold start dead cylinder
- v6 vacuum lines
- Moog Balljoints problem
- Which 3.0 to put in my rig?
- auto tranny problems
- oil pump drive gear broke in half??
- 83 thirds in 90 truck
- Anyone else been locked inside their truck?
- 89 22re engine trouble
- Cruise light comes on when I hit the brakes, what the heck???
- need some advice here on my rigs.
- starting question
- 89 project truck
- 84-89 vs 89-95 A pillar compatability
- exhaust problems
- is this differential normal? (pic)
- synthetic
- 4Runner Back Glass
- Little update on my runner
- Mixing regular coolant with Toyota 'Red" coolant
- New here, want to say thank you & my rig
- 22RE crank but no start - got fuel and spark
- pictures of my 89. Scuba?
- 1987 22R-alternator doesn't charge at startup
- Air injection removal
- front spindle question
- 4Hummer S.U.T. with Can-Back idea
- HELP! need OEM part#s for 22RE injector seals & pintle caps
- hannemann tundra fiberglass conversion
- Need help with rad problem
- Im going crazy!!!
- Hard to start, Super Rich
- Tire slime
- Open element filters and mud
- ebay gaskets/timing kits
- Dash & Tail lights DON't WORK
- Front Bumper Assembly
- Trans output seal
- Rear Tailgate Window problems on 1st gen 4Runners
- 2nd gen runner rear axle link broke!!! how important???
- Swapping Truck 60/40 seat for 4-Runner bucket seats?
- Swap from 3.0 to 3.4
- Timing Belt
- CCA'as for a 22re?
- 22re that runs wide open as soon as it fires up
- Swapping in Tilt Steering into a 94 truck
- 86 4Runner radio harness wiring diagram?
- 22r thrust wash question...
- 1990 4runner body lift...will throw distance be a problem ??????????
- tune-up question, worth it to buy?
- Where is the cold start time switch? (3.0)
- brake bleeding question
- frustrated!
- This week's official 4runner hacking...
- help! 22re injector seals
- Receiver location?
- Anybody ever built an Ivan Stewart replica?
- code 51 help??
- Exhaust
- Brake Line Questions
- Got bored today...
- Glowing Red Turbo, Normal?
- Couple of tech questions
- Rough Idle on warm start
- Looking for smittybilt front bumper
- HELP Confused on land cruiser coils
- headliner heat
- Use the right tools.
- 86 pickup running wierd
- Building a baja desert runner
- 91 truck blowing the efi fuse
- Want to lift, but need some help.
- Coolant level Rising
- Hello! Just bought my first Toyota
- Cam replacment
- anyone emissions tested w/ a Supra AFM?
- 22r/re engine help!!!
- i just bought a roll bar for my pickup :D
- Transmission shudder
- Butt dyno
- 92 4x4 truck leaf springs and e-brake cable
- Need some help deciding.
- 22re smog/ egr block off
- no power to fuel pump????
- Fuel Pump assembly
- 88 4Runner power windows
- Head removed but forgot to break pulley bolt
- Front diff binded up?
- Window Weatherstrip Source Needed
- Wow, my engine was bad!!
- 35" x 12.5" x 15"
- Engine Video-help Diagnose me?
- 22ret heat problems
- Difference between RN 50/55 and RN70
- bolt-on rear shock mounts - good idea?
- 91 toyota pickup air intake
- Here we go...... starting issues with the 89.
- HELP! my exhaust manifold glows bright orange after being on the highway???
- yet another flat tire today...time for some new tires, more Revos or??
- It passed!!!!!
- Carb Rebuild: 1987 cut out/hiccup on deceleration.
- O2 sensor Relocation ?
- What to look for on older 3VZE's
- Transmission went bye bye, Part II...
- Turbo exhaust?
- HiLift on stock bumper?
- idle missing help
- Complete dash swap over from 89/94 to 88?
- Started The Ole Bed Bob Today!
- New here... need help with 86 22RTE turbo
- Truck smokin?
- '91 22REC 2WD oil pan OUT!
- slip yoke axles
- bad fuel injectors?
- Wheel fell off...
- Headers on 22rE, loud?
- rpms on hwy
- Truck stalls when braking
- intake roar, 22re 89 4runner
- please help with indicator light wiring
- Sticking throttle cable?
- filling torque converter
- coolant leak
- '82 Supra Throttle Body swap
- h4 conversion lenses
- Price check
- Who's got a turbo re besides me?
- idle problem with 22re
- buying a new 3.0 3vze engine wondering what block i should buy heres some links
- windshield wipers
- 3VZE Timing belt, water pump – Newbes you can do this
- Water sloshing around in my dash??
- 4runner half top
- anyone ever considered tracks on their yota?
- jungle fender flares
- CA Smog Help...
- Where to get a rocker panel
- 4wd Part
- air intake mods
- Snorkel for the 3.0
- catalytic converter question?
- steering wheel removal 88-runner
- 1" body lift and new bushings
- Hestitation
- Third member ?
- Pulling codes?
- getting to the bottom of my idle issue...
- Thoughts on FJ60??
- Roof Rack
- rear pumpkin install. stuck partway
- New to Vancouver, WA - Can anyone recommend any Junk yards and mechanics?
- Ball joints?
- Auto tranny A44D: which is the cooler return line?
- part source recommendation
- high idle and low idle???
- fuel leak at pump/sending unit, need a new. . .something
- dual cases question
- Truck Runs Wierd At Start Up
- continuous intake leak, stud kit
- Move is overwith, time to work on the truck again! Electric fan & relay install
- radiator recommendations?
- shackles
- 94 ext cab wanting to lift 2"
- dents in the bed
- which lockers?
- Belt size, lame thread
- odd throttle issue 3.0
- Winding sound on '93 2WD 4Runner
- Inchworm Rockstomper Motor Mounts
- Trouble with my 87 4Runner
- 4Runner Yotatech stickers?????
- Starting problem
- hmmm...vinyl or carpet?
- Winch Opinions
- SASed time for gears and dual t cases...help
- redlining?
- o2 sensor question
- Question about installing cylinder head on 22r
- cold air
- how do i relocate the ecu??
- If i wanted to bore out a throttle body
- 22re afm test
- Shock options
- 22re High Idle - Drops with AC Compressor
- LEER Camper Question? How much did you pay for yours?
- my runner chop input please:)
- Engine swap - How to make the A340 work?
- Check engine light help on 87 4runner 22re
- rear end problems
- How do you make your truck Submergable?
- body lift help
- Indepentdent Suspension Question
- High Idle in Neutral only on 88 4runner with 22re 5 sp
- 10.5" Tundra axle vs Full Float 8"?
- rf1a transfer case shift pattern
- My little red wagon (or 4runner...)
- 90 4runner, died while driving
- New head bolts or not 3.0
- Notches for MC bumper.
- Huge starting problem, please help!!
- Snow Day!!!!!!!!!!!!!
- I got my 4.88's but need some help.
- axel boots
- bad tps?PLEASE HELP
- What do you think of this head gasket set?
- Real world BJ spacer flex
- Better Than Stock Suspension
- Throttle sticking
- source for 4runner sliding window frame
- question on idling
- High Idle (2000-3000 rpm). Advice? Please?
- can anyone recomend a brand of fan clutch?
- Rancho rs5000
- CV axle breaking. HELP!!
- Light Bar
- 22re wont start.New starter
- Am I lookin at a bad head gasket or what?
- proper o2 sensor
- Fuel in coolant.....???
- new yota wondering about lift
- trans swap
- Clutch bracket?? What is this and would this prohibit me from getting in to gears?
- Loud Engine Noise
- New Master and Slave Cylinder...Bealry any Pedal, cant get into any gear.
- Made it to Vancouver, Wa.... BEWARE OF Uhaul DEATH TRAPS.
- custom front bumper 90 4runner sr5 v6 3.0
- selling my baby! 87 4runner
- This is where it starts, and it just goes downhill from there
