h4 conversion lenses
Old Feb 25, 2009 | 01:14 PM
toyotanick's Avatar
i am looking into the all-pro H.I.D kit and all it includes is the bulbs and ballasts. my problem is that my lenses are sealed and do not have a a removable bulbs so what can i do to change that? i have heard something about an h4 conversion but do not know what that means or is or how to get it haha so any help would be greatly appreciated!
Old Feb 25, 2009 | 01:56 PM
Flash319's Avatar
Hella sells the H4 kit. I just installed it in my truck. It is a glass bulb just like you have put you can put the bulbs inside it like a regular style light.
Old Feb 25, 2009 | 03:47 PM
Jay351's Avatar
Hella e-code lense. Great pattern, and you won't blind anyone with the sharp cutoff.
H4 is the type of bulb.
You have sealed beam headlights. I.e when it burns out, you replace the whole light, not the bulb. Obviously these replacments never get that much R&D put into their lense pattern.
A non sealed beam 'h4 conversion' gives you a dedicated lense/housing. Then you can change your bulbs to some of the many many aftermarket selections
Old Feb 25, 2009 | 04:04 PM
Flash319's Avatar
Jay:
Both my lenses are the same. Is there a left and right? The pattern looks one sided?
Old Feb 25, 2009 | 04:09 PM
abecedarian's Avatar
my 9004 replacements are the same pattern left to right: they both have a sharp cut-off (dip down) to the left (it's the USA so we drive on the right and a sharp cut-off to the left helps oncoming traffic not be blinded) and on the right, the lenses flare the pattern up to help light up road-side signs... and they are DOT legal.
Old Feb 25, 2009 | 07:33 PM
toyotanick's Avatar
i cant seam to find these lenses...
Old Feb 25, 2009 | 08:35 PM
Elton's Avatar
ebay is your best bet
Old Feb 26, 2009 | 06:31 AM
Toyotero's Avatar
Originally Posted by Flash319
Jay:
There is not a left and right model light... R and L are the same.. They both allow light to leak above horizon on the curb side.
For e-code lights, there are right hand drive and left hand drive models (because the curb is on the opposite side too). Any reputable retailer will sell you left hand drive lights if you live in the US.
Gene.
Old Feb 26, 2009 | 08:42 AM
Flash319's Avatar
Well the slash cut triangle is towards the bottom of the lense and facing towards the oncoming traffic.
Old Feb 26, 2009 | 09:10 AM
annoyingrob's Avatar
Yeah, but if you look at the beam pattern on a wall, you'll notice it's mirrored, going up, and away from traffic
And Hella E-codes are about the best housing you're going to get. Spend the money on them, especially if you're going to be putting HID retrofits into them. Cheap ebay housings may work OK for standard halogens, but just scatter waaaaay too much with HIDs. I run a set of Hella E-codes, and HIDs on my Supra, but it's in storage, so I can't post pictures of the cut-off. It's pretty damn good though.
Old Feb 26, 2009 | 01:59 PM
Jay351's Avatar
thanks for clearing it up for me
Get the e-codes, such a nice lense. Check my cardomain for pictures of the parts and the lense pattern on the road.
I really feel the e-code lense pattern is so much smarter then the regular DOT pattern. The e-code lays down smooth even light with a very sharp cutoff. Unlike the dot which kinda throws the light everywhere, including up to light up overhead signs (and blind other drivers). I have yet to notice any cons for these babys
They are DOT legal in canada at least
p.s these lights can be had (I got mine here) www.rallylights.com
Old Feb 26, 2009 | 06:57 PM
toyotanick's Avatar
thanks jay351... but now that i found them what do i need? h4200mm headlamps right? and should i get the vision plus or just the regular...
Old Feb 26, 2009 | 08:22 PM
Jay351's Avatar
200mm is the size and h4 is the type of bulb. yes
http://www.rallylights.com/detail.aspx?ID=354
get those
Old Feb 26, 2009 | 09:10 PM
Elton's Avatar
see my thread on my ebay lights there $40 dollars a pair and there e codes
Old Feb 27, 2009 | 06:20 PM
awareness's Avatar
What's the difference between an E-Code and an H4? Also in price typically? I bought Hella H4 Vision Plus lights for mine and upgraded to a slightly more powerful bulb.
Old Feb 28, 2009 | 11:39 AM
Jay351's Avatar
E-code is the style of lense (european code) And h4 is the kind of bulb.. Totally different subjects.
Old Mar 1, 2009 | 08:29 AM
awareness's Avatar
I see, so my lenses would be E-Codes then? Because they have H4 stamped in the glass.
Old Mar 1, 2009 | 08:38 AM
iamsuperbleeder's Avatar
H4 is the type of bulb, be it E-Code or not. E-Code and H4 have no relation to each other; they mean to completely different things. The headlight could take a 9006 bulb and still be E-Code. E-Code headlights are just as he said, for European vehicles; the spread pattern on their headlights are different from North American vehicles. Normally you'll notice this in the way that the light beam tends to slant downward on the left on American cars. If you order E-Code conversiona, the light pattern remains flat (which BTW I believe is illegal by DOT standards in the states, due to the fact it directs light right into oncoming traffic).
Just because you have H4 bulbs does not mean the lights are E-Code.
Post a pic of your light, we'll be able to tell you if their E-Code just by the way the reflector looks; normally is easy to tell on these square beam lights
Old Mar 1, 2009 | 09:12 AM
Outsane's Avatar
I have a set.. love em..
I even put HID's in them for a little bit
I can get sets of the bulbs too if any one is still looking for them
Old Mar 1, 2009 | 09:33 AM
I'm running a set of E-Code conversions myself and I love em, but one's leaking I just haven't got around to replacing them yet; the bulb hasn't burned out yet somehow...
