10.5" Tundra axle vs Full Float 8"?
Old Feb 23, 2009 | 09:21 AM
T-1000's Avatar
What would be stronger?
A rear Tundra axle with the 10.5" diff like this
http://www.4wheeloffroad.com/techart...xle/index.html
or a regular 8" differential axle with this kit on it
http://frontrangeoffroadfab.com/nfos...06e62fd0182578
The only thing is there don't seem to be any lockers for the 10.5". Maybe a T100 axle (the so called "8.25") with the full float kit is the way to go?
http://home.4x4wire.com/erik/diffs/
Old Feb 23, 2009 | 10:24 AM
Matt16's Avatar
The 10.5" Tundra axle is going to be the strongest obviously. Read the article you posted, that thing is huge. While its not a full floater, look at how they beefed up the portion of the axle supporting the weight of the truck:
What could you possibly need more axle strength for, the Toyota 8" is very stout already?
Old Feb 23, 2009 | 10:58 AM
T-1000's Avatar
Ah, just curious. I don't think I'll ever be grenading a full float 8", but if I happen to come across a cheap Tundra axle...Do they have discs in the back?
EDIT: No it's a drum.
I bet they're way different widths though.
Old Feb 23, 2009 | 02:00 PM
tc's Avatar
tc
I guess it depends on how you look at it ... Tundra axle will be a helluva lot harder to grenade, but when it does, your wheel comes off.
8" FF will break easier than the Tundra, but you just remove the broken part and drive on ...
Old Feb 23, 2009 | 02:16 PM
bigt's Avatar
and a full floater gets you rear manual hubs and that my friend is totally ballin outta control
Old Feb 23, 2009 | 02:18 PM
mt_goat's Avatar
Originally Posted by tc
I guess it depends on how you look at it ... Tundra axle will be a helluva lot harder to grenade, but when it does, your wheel comes off....
And you know all about having your wheel pass you don't ya TC.
Old Feb 23, 2009 | 02:19 PM
tc's Avatar
tc
Yes, yes I do.
*NOTE: It was Molly's truck, not mine!
Old Feb 23, 2009 | 07:27 PM
Matt16's Avatar
Have fun grenading the Tundra axle... I wonder what it would take to do so
Old Feb 23, 2009 | 07:37 PM
tc's Avatar
tc
Dual cases
I'm sending 36,000 ft-lbs of torque to the wheels. I have sheared front axles at the shaft (not the joint/boot).
No axle is designed for that.
Old Feb 23, 2009 | 08:50 PM
T-1000's Avatar
Dual cases
Man...I want dual cases haha.
Old Feb 23, 2009 | 09:14 PM
Matt16's Avatar
Dual cases
Wouldn't the tires loose traction way before that (unless they were wedged). Any idea what the tires can take in terms of torque before the lugs tear off, the side wall tears or separated from the bead.
Old Feb 24, 2009 | 01:01 PM
tc's Avatar
tc
Yes, there is no way the tire can generate that much friction - wedged is the issue. I can tell you on the front that the Warn manual hub, the lugs, the R&P, and the diff stub shaft have all survived when a CV shaft hasn't ... my hub dowels ARE in pretty sorry shape though!
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
konah
Jul 30, 2015 02:08 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jul 23, 2015 11:20 AM
Suprarossa
Jul 6, 2015 05:21 AM
