Inchworm Rockstomper Motor Mounts
Old Feb 23, 2009 | 11:35 PM
wancosc356's Avatar
Has anyone ever used the Inchworm Rockstomper Motor Mounts? Whats your opinion on the quality and durability? Are they direct replacements for the stock mounts? Thanks
Old Feb 24, 2009 | 06:46 AM
muddpigg's Avatar
I didn't like the price tag, so I followed set up found on pirate's faqs. a 1/2"X3.5" grade 8 bolt. Drill a hole through both sides of motor mount put bolt through. Works great, fraction of the cost, like playing Tetris to motor back in. But another option is to use a legnth of chain to limit motor movement.
Are you running "ultimate crawler?" If not you really don't need them.
Old Feb 24, 2009 | 11:04 AM
riceburner's Avatar
A friend of mine had vibe problems with an older set (also fitments issues IIRC). The stock mounts with a length of chain are a better option in that respect.
Old Feb 24, 2009 | 11:35 AM
wancosc356's Avatar
Im not sure what running "ultimate crawler" is? It is a very mild off road truck. Nothing fancy at all. I just notice a bit of movement/jolt with quick acceleration or deceleration. I can get stock motor mounts for $75. The inchworms are only $5 more plus shipping. Im not interested in modifying current mounts or "putting chains" on it. I want a good replacement. If you could suggest one better, please feel free to let me know. Thanks
Old Feb 24, 2009 | 12:30 PM
muddpigg's Avatar
The reason those mount are made is for the increase in torque the drivetrain experiences when really geared low, like with the ultimate crawler (two reduction boxes on geared factory 2:28 and one geared 4:70). With thest drive train changes the resulting torqoue on motor mount will rip them apart, very bad.
It sounds like yours are simply worn, if I was in your shoes I'd go with stock style mounts as its rumored the the rompstomper mounts transfer vibration to the chassis/body more. I've seen them for sale used because of this reason, someone got them and decided it wasn't practical for their needs. Good luck.
Old Feb 24, 2009 | 12:32 PM
wancosc356's Avatar
oh ok. i understand now. thank u very much. i appreciate the info.
Old Feb 24, 2009 | 01:08 PM
BigBluePile's Avatar
The rockstomper mounts do transfer some vibes. It'll probably drive you crazy if it's a daily driver. I only drive mine every once in a while. I have one installed on the drivers side and a brand new factory mount on the passenger side.
okamikai
Apr 30, 2018 10:19 PM
Scotto6591
Sep 1, 2015 03:24 PM
keithporter83
Jul 24, 2015 07:37 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
jon.r
Jul 11, 2015 03:34 PM
