Rear Diff and Driveshaft Advice? 88 4runner
Old Feb 21, 2009 | 05:58 PM
MillRiver's Avatar
I've got an 88 4Runner V6 manual w/235K. Awesome truck, I love it.
About a year and a half ago I replaced the stock rear springs with OME. Install went well enough for someone with my limited skill. Afterword she shook like a sonofabitch however. Realized the lift screwed up the alignment of the driveshaft. After about 6 months of shimmying I got a guy to make up a couple shims to correct the DS angle. The driveshaft was aligned but it still shimmyed a little and got pretty loud on the highway.
This past week I took her on a 400 mile highway drive. Realized today the rear diff was totally dry. Completely. My lazy ass hadn't check it since my son was born a year ago. It sounds like there's a coke can floating around in there.
In addition, now she's shimmying like before I installed the shims.
Question for you guys with much more knowledge/experience than I... Any good articles out there on rear diff rebuilds? And, what are the chances I torqued my driveshaft back when I lifted it 2" and the recent highway driving torqued it further. (The driveshaft looks straight to my untrained eye)
Thanks...
Old Feb 21, 2009 | 06:29 PM
waskillywabbit's Avatar
Sounds like you got your u-joints out of phase. Your diff shouldn't just go dry.
Old Feb 21, 2009 | 06:39 PM
Plumbrbob's Avatar
x2 sounds like u-joint
edit: I have 4" of lift in the rear and have used shims and not used shims no shimmys or shakes either way.
Old Feb 21, 2009 | 08:20 PM
son_of_a_lc's Avatar
ome springs shouldnt be high enough to require shims. I agree, probly your u-joints bad, and yea, thats wierd that you diff would just go dry.....maybee someone really needed 90W and siphoned it out of your axle.
Old Feb 22, 2009 | 09:12 AM
Matt16's Avatar
Or, maybe it leaked out the plug or axle seals.
You've probably ruined the diff and your U-joints sounds like they're cooked. Used diffs aren't expensive. I'm assuming you have a 4.10 diff which you can pick up for between $25 and 60.
Try lubing the U-joints one at a time to figure out which one is the problem, or just check for play if they're bad.
Team420
Jan 12, 2021 04:57 PM
Valvoman
Jun 28, 2015 02:45 PM
merc1100sc
Jun 26, 2015 05:24 PM
cchinny
Jun 25, 2015 08:11 PM
