- Toyota pickup 1986 2 L-T turbo Diesel
- 1989 22r with double-row chain?
- compression test
- regarding 35 inch tires
- 1988 4runner 22re cuts out on acceleration
- crane street ignition kit. 3vz
- Setting up my new lifted 4Runner
- Front wheels not engaging in 4WD
- A340H Solenoid one part number (Toyota or Transtec)
- '87 Needs New Engine. Buy or Pass?!?!
- higher oiling rockers 22re performance
- 94 3.0L 3vze v6 pickup auto Boggs down under load or once at cruising speeds
- Swimr@DaResq-'94 Yota Pickup-New to Forum and offroad
- Need your input Yotatech
- 1993 4Runner questions
- Help with part name for Armrest mounting 91 PU
- Recommendations? HID fog lights
- 3vze acceleration problem
- 87 pickup losing coolant
- Looking for a Rear Bumper for 94 Pick up
- 1991 ECU ECM pinout
- Removing LCA Bushing Metal from 2WD Pickup.
- Shocks
- MSD Ignition Coil
- Stiff gas pedal/timing cover gasket
- Replacing green coolant with Toyota red.
- Leftover wires and Hose??
- Oil Pressure? 2.4re
- Time to fix, or sell my 1994 Toyota X-cab V6 4X4
- 3vze with 170,000 miles with not a single leak. What do you guys think?
- steering box problems
- 3vze upper end knock
- Faulty igniter?
- Slave cylinder bleeder valve thread size?
- Toyota newbie
- Engine running rough
- Should I remove another leaf from the front
- Axle chunk question!
- Auto Trans suddenly revs like in nuetral
- 86 pickup no spark
- Whats Wrong Here
- Chevrolet Step Side Build Up Thread
- 93 toyota extra cab with 3vze with auto transmission
- 3VZ-E Bosch injectors & broken EGR valve
- Mfr Body Code?
- Inconsistent idle, and slow response thottle snap
- Why NOT to procrastinate...
- 95 3.0 only running on 3 cyllinders
- Need flexible fuel hose for 1994 Pickup
- Few questions from a noobie
- Extra Auxiliary gas fuel tanks???
- only dask background lights not working
- drive shaft broke
- Plate style front bumper
- blower motor not working
- Electric exhaust cutout on 1KZ-TE
- Power Steering Hose - Any "New" Replacement Tips!
- mechanical windows not working
- opinions on steering arm adaptor to fix tie rod geometry
- Im new in the toyota world. HELP
- steering wheel swap
- Tps question mounting direction
- Seafoam through brake booster on 3.0
- what seats will fit my runner
- no heat at temp. blows cold air
- Runner 3vze Mystery Part
- 89 pickup 3.4 swapped brake issues
- temp still dropping and downshifting after warm up .
- Tool for holding timing gear when removing head
- Whats a good replacement rear axle shaft?
- lug lug lug
- 91 toyota running hot?
- 1988 pickup no fuel at cold start injector cranks no start
- Just joined
- CV Axle/Hub problem- HELP!
- Long crank time
- radiator part number
- Stumped on transmission mount
- In process of removing EGR, need help!
- 94 4runner dash warning lights flickering/engine missing
- New 92 runner owner
- Motor rebuild 90 4runner V6
- 95 runner...body or engine swap?
- Up and running
- 1986 4runner roof rack idea
- Lugging Vibrarion at WOT... Come Along For The Ride
- Zuk Mod vs. Lift Block
- Gas Mileage HELP
- 89 pickup blower switch challenge
- I need a gearing expert to help me out, please.
- 89 22RE stumble/bucking/misfire
- 3VZE Transmission Squealing/squeaking
- Code 27 ???
- 90 4runner acceleration problem
- Buyer beware Dorman fan bracket garbage
- Bad tps?
- spare tire carrier 2wd / 4wd adaptor?
- Removing throttle body 22re
- carb wont feed any gas out
- Starts great cold- dies after warm up then runs great
- 22RE Water Pump to Throttle Body Blues
- 1988 4Runner V6 - Starter replaced, clutch pedal acted up
- 22RE Distributor "Cotter?" "Pin?" "Dowel?"
- 2.4 sputtering/rough running at low idle
- 90 30 slow wont start after starting
- Gas Leak from 1991 4x4 Regular Pickup
- 1989 toyota 22re
- at temp, bat, and brake light on
- Pushing on fuse block affects battery charge?
- Need help identifying a part and how it is to be plumbed
- 1986 xcab to 4runner exhaust
- 22re turbo motor wont run
- Coolant spilling out of Reservoir
- Front seal leaking... how good are the repair sleeves?
- 22re weird bogging problem
- Ring & Pinion Gear Options for 37" Toyo M/T tires with 5" lift..
- Door latches kicking the lock button up
- 91 4×4 pickup (3.slow) tranny problems. HELP
- no heat after engine swap
- Fair Price ?
- something in my intake manifold?
- 22RE cutting out.
- 87 carbed 22re power upgrades
- Front Long Travel Kit
- 4 link Rear Suspension
- Power Windows/Locks
- New to Forum...
- Odd clutch disengagement problem.
- A Search For My First Toyota
- Looking for a torque spec
- what 22r year block is this?
- can spare tire winch be disassembled?
- #4 zero compression
- Crank replace, turns over wont start
- 1986 Toyota SR5 extra cab
- Fuel pressure pulsation damper question
- Help with these numbers
- 3vze distributer
- '87 bed interchangeability?
- 3rd gen p/u to 2nd gen 4runner rear bumper
- Look what I had to build/make/construct/fabricate!
- Dash goes Rrr, Rrr, Rrr. Speedo cable?
- Lower ball joint failure?
- 3vze oil pump leak
- 1st gen IFS 4Runner passenger side lean
- Factory cab over weber carb, problems
- 3vze
- Nitrous anyone?
- Coolant in all cylinders, HG looks ok
- Passenger Side Gap Guards
- 195/75r14 bfgoodrich ta ko, any thoughts?
- Spark plug not wanting to come out
- 88' 4wd 22re manual tranny question?
- Toyota Rock Defense Front Frame Reinforcement Kit Questions about install
- smittybuilt bumper
- 1993 Toyota Pickup CRANK, NO START
- truck idling extremely low/dying after driving
- Wait or buy locally
- 3.4 Auto ECU with 5speed swap CODE HELP!!!
- Does anything connect here?
- So sad, my poor baby
- 22re oil pump/smog related
- Aftermarket Radiator
- Deck light
- cat stolen :/ straight pipe?
- Custom LED Turn signals in Corner lights
- 93 4Runner SR5 V6 Fail on emissions test @ NO(PPM) 15mph
- Steering knuckles are bent :( Got ideas?
- Clank in driveshaft while starting in reverse
- 22RTE stumbles, hesistates, misfires, surges. HELP!
- 86 4rnr idle issues
- Lifter tick? maybe?
- 89 4 runner 3.0 owners manual
- 3.0 timing belt questions
- Finished SAS build
- Blue Devil Head Gasket Sealer, Does it Work ????
- Freaking brakes!!!!!!
- Weber plugged?
- 4 wd will not engage 1988 pu manual hubs
- Can an IAC leak coolant into the intake manifold?
- Third member install question
- Truck not starting, just clicking.
- Alternator upgrades on a 22re
- 86 pickup fuel sending unit problem
- What type of oil and oil filters do y'all use?
- Crankcase Position Sensor?
- Shifter boot. Loud, smelly, need fixed.
- Rattle noise only in fifth Gear
- Another Engine
- timing for 22re camshaft and crank
- Clockspring / modern steering wheel swap?
- 86 22r pickup, couple of issues, please help!
- Missfire '92 4Runner 3.0L 3VZE
- 92 Pickup Battery issue
- Clutch Fork squeak
- dash board removeal?
- 93 22RE oil pressure switch
- 1995 into a 1994, 3VZE swap
- TDC - water pump change
- 4x4 Light
- 1994 pickup 3vze engine rattle? pinging? Surging?
- Mystery Part, please help
- Can you name this mystery 3vze part?
- My rear driveshaft fell off at 140km/h
- What is this connector for?
- Firing Problem
- 1991 3vze stumbles only when started
- Rear folding seat knob
- speedometer hand replacement
- 22RE Head Thickness Spec
- Online O.E.M. parts who/where to find ?
- Fuel filter mod?
- E-brake cable sagging
- Engine making 'gravel in tin can sound'
- top seed??
- Total Frustration
- Couple of rebuild questions
- Rolled my Yota
- how do you make an 88 longbed fit a shorbed frame?
- Cyl Head
- blowing black smoke and running really rough
- $500 working 92 4runner
- New clutch not engaging, and making skreetchy noise.
- 3vze fan shroud replacement
- 4Runner starts and then immediately dies
- SPECIFIC Questions...
- Power steering leaking
- 95 4runner 3.0 V6 code 2552
- cleaning throttle body, should I remove that plate with four screws...
- Weird sound???
- 22r 22re torque plate rental
- 94 Pickup Power Mirror Glass Repair?
- Highway Speed High Coolant Temps
- 1st gen seat swap
- 22re back to basics 1st timer rebuild questions
- 93 FSM link down or changed???
- No Fuel
- Broke Fuel Line - What are my options?
- Cam and valve suggestions for 3VZ
- anybody order body panels from these guys?
- 87 4Runner Engine Build
- New to me 4Runner. Anybody any reconmendations
- '94 toyota temperature range
- 86 Runner Injectors Not Firing - Help
- Anyone smelled gas after spinning out?
- 3.0 V6 Rant
- Tps issues
- AC No Longer Cooling 1991 3VZE 4x4.
- Help! Rear anti lock light on
