4x4 Light
Old Sep 29, 2013 | 03:19 AM
benja455's Avatar
4x4 Light
So, one of the very last issues I need to resolve on my 1995 22RE 4x4 is that the light which indicates 4x4 is active does not work.
I have the manual Asin hubs and the 4x4 absolutely engages and works - I've tested it. I have also confirmed the light isn't burnt out. The PO said he noticed the light wasn't working several months after he had the clutch replaced. He suspected a wire wasn't connected again when they put it back together. Thoughts?
Where would this wire be if that was the case?
Old Sep 29, 2013 | 07:28 AM
INFINITY's Avatar
the wire coming from the 4wd light on the gauge cluster is the ground side of the light coming from the dash to the switch on the t case that grounds out of the frame or through the t case. depending on if the switch has one wire or 2 coming out of it......
Old Sep 29, 2013 | 07:29 AM
aztoyman's Avatar
Not sure how your 95 is set up but, my 88 has a switch on the T-case that turns the light on when you engage 4wd.
Yours should have a similar setup. Find a wiring diagram.
BigBluePile's Avatar
It's on the tcase. Real easy to find.
Old Sep 30, 2013 | 05:30 AM
Innocent Fool's Avatar
If you have ADD there's also a connector on the front diff
raptor510
Feb 17, 2017 07:11 AM
Sep 4, 2015 09:27 AM
Odin
Jul 15, 2015 09:28 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
madxman21
Jul 9, 2015 10:26 AM
