Oil Pressure? 2.4re
Old Oct 16, 2013 | 02:35 AM
Hooperdog's Avatar
Arrow Oil Pressure? 2.4re
Hi, I'm new here and need to learn a few things about my new to me truck.
94 4x4 Reg cab with 22re & man trans. It seems to idle low once warmed up like 500-600 rpm's and the oil pressure drop way down at that time (almost all the way to the left but not quite all the way).
When I drive it the pressure goes up to the middle of the gauge. just wanting to make sure that's ok/normal.
Just got the truck it's been sitting for a while, got it running and still in progress, replacing tank & fuel filter today, fuel pump is new. oil & filter are new, rad, just flushed out. Thanks in advance...
Old Oct 16, 2013 | 06:41 AM
osv's Avatar
osv
get a timing light with a tach on it, set everything per factory spec.
Old Oct 16, 2013 | 04:38 PM
stinkfoot's Avatar
Yes. It's normal. I can't remember the exact settings right off, but it should idle high until warm, and then drop down. 1500rpm and 700rpm, maybe. There should be a label under the hood that tells you the appropriate setting. Your oil pressure is typically going to be lower at a lower idle. Keep in mind that the dash gauges aren't particularly precise. You'll have to test it to know for sure.
Old Oct 16, 2013 | 04:43 PM
Hooperdog's Avatar
Thanks, it idles about 1400 at cold start and 500 when warmed up, sticker under hood says 750-2wd 8504wd. That's why I was wondering.
Old Oct 16, 2013 | 08:20 PM
stinkfoot's Avatar
Yeah, the idle is real low. Shocked me at first. I'd rather it idle closer to 1k, but don't know a way to make it do that without bringing the cold idle up really high. Some of these other smarter guys may know a way to make it happen.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
