PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. First-Gen 4runner Rear Seats
  2. Throttle body Coolant lines/Part numbers?
  3. Found plastic pieces in my oil pan? How do my valves look?
  4. Torsion bar Adjustment
  5. 1986 2WD SR5 Longbed - Converted to Diesel
  6. '94 4Runner SR5 4WD, 2.4L, Great tool for pressing front bearing races
  7. power steering bolt -at my wits end!!!
  8. 30 YO open recall on my ‘88.
  9. Replaced clicking starter- No click, No start now.
  10. '88 22RE, advice on rebuild/tuning an AFM?
  11. Transmission options for 22rte
  12. Help please! Several issues with my 92 Toyota 4Runner 3.0L 4x4!
  13. Need parts 93 pickup 22re
  14. Odometer/Speedometer/Fuel Gauge trouble
  15. 91 Pickup 3.0 - Code 25
  16. Anybody else kill idler arms regularly?
  17. Looking for used lift spindles
  18. 1992 clutch / brake pedal assembly. Right part.
  19. ABS wheel speed sensor?
  20. No ignition spark after reaches operating temp 89 sr5 3.0
  21. part in the power steering assemble
  22. What is this thing?
  23. What is this thing?
  24. 80 Amp Alternator Fusible Link in 1994 4x4 Pickup 22re
  25. LC Engineering 22RE turbo kits
  26. 89 toyota truck 3.0 sr5 no ignition spark
  27. ARB bulkhead thread size
  28. '87 Turbo Restoration and Build
  29. Vin Decodee API
  30. Replacing drive belts, need help with parts
  31. 88 4runner AC/Heater Control Light not working after replacing the bulb
  32. Cold idle lope 88 3zve 4wd.
  33. Wiper intermittent is not functional. 88 V6 4wd.
  34. which size and type of valves for my 22re
  35. Repair/Replace 1st Gen Power Antenna Mast?
  36. 2nd Gen Rear Differential Rebuild Question
  37. Another 22re turbo thread
  38. 85-95 lcengeering timing cover issue
  39. 86 Toyota SR5 Problems
  40. how can I add wire for tachometer because i want to change the cluster with one has t
  41. 22RE AC idle
  42. ECU pin out for a 4Runner 1991 v6 MTM
  43. What year did the A340H no longer have a transfer oil cooler?
  44. 93 2wd Windshield Removal
  45. Replacement fan blade wobbling
  46. Total newbie needs advice
  47. How to jack up 22re engine?
  48. Got my first 4Runner
  49. What is this plug?
  50. Fuel gauge shows full even with key off in a 92?
  51. Letter and number stamped on my 3vze pistons
  52. AFM Swap work with this part from Autozone?
  53. Looking for advice on parts
  54. '87 SR5 Turbo - 2nd Gen Brake Upgrade Worth It?
  55. '87 SR5 Turbo - Which Ring Gear for Rear Diff Gasket
  56. Two belts are rubbing now...?!
  57. 1993 DLX Restoration Project: Some Questions and plans
  58. Anyone in Georgia?
  59. '87 SR5 Turbo Automatic has Really Soft Brakes
  60. Torqe for bolts
  61. Steering Wheel Vibration while Stopped in Gear (Automatic SR5 Turbo)
  62. Help!!! So Confused
  63. 5th Tire Hoist chain.
  64. 85-95 Cable bracket Anyone know where I can get one?
  65. Turn 3 4runners into 1
  66. Installing a tachometer
  67. ARB compressor mounting
  68. Help fuel problem
  69. Gear drive transfer case onto 3vz-e manual tranny
  70. AC CDS Fan issue
  71. Fuel sending unit sensor
  72. 1988 3.0 Timing change
  73. torsion bars
  74. Part number doesn't exist, how could that be?
  75. skateboard tricks and first gen 4runner
  76. Head bolt stripped during installation, redo right?
  77. Fuel line to an help
  78. 86 yota cut off and wont crank
  79. forward clutch end gap
  80. Need help decoding VIN/Model plate
  81. how to remove windshield trim before painting?
  82. Console switch-back window goes down but not up:One Solution
  83. rough idle after highway driving
  84. ARGHHHHH 3VZE valve bucket too.
  85. RET to RE
  86. '94 4Runner 4WD, 2.4L, 31" x 10.5" radials (on 16-3/8" rims?) - newbie to forum
  87. Worn out, useless keys
  88. Code 52 knock sensor
  89. Remove B-pillar trim when painting or tape them off?
  90. Stumped, truck don't run
  91. Shorted battery after rebuild, will not start
  92. 1986 Toyota Pickup Rattle in 4th Gear
  93. 1990 4Runner with surging idle and stall problems on warm startup
  94. Floor Mat Front
  95. Help, Truck loses power stutters at high RPM
  96. 1990 pickup bed dimentions
  97. Help Testing O/D Relay - Relay has 5 terminals, but FSM shows 4 terminals
  98. Couple questions about my 88 T4R
  99. Blower motor RPM adjustment knob?
  100. Blue smoke out tail pipe after idling
  101. Vibration When down shifting after 63" spring instal
  102. Hose to Fuel Pump (22R) Question
  103. '94 3VZE EFI fuse blows immediately when fuel pump runs
  104. Will 2017 16" TRD Tacoma wheels fit a 1986 ifs 4runner?
  105. 91 22R-E Idles high with idle screw all the way down.
  106. I seem to be missing a pin for ECT port on Diagnostic Connector???
  107. 3vze Oil leak / Diff runoff
  108. Low compression on cylinder 3
  109. 1993 4 runner leaked out almost all the coolant while sitting cold had a brand new ra
  110. Question about temp guage
  111. RANCHO steering damper / stabilizer
  112. Rust hole in the bed
  113. Rebuild engine or replace
  114. Split shift
  115. Just bought 86 Pickup - couple questions & hesitation issue
  116. How can this NOT be a head gasket issue?
  117. EFI Fuse blowing
  118. Factory A/C Charge Amount
  119. 1989 pickup clutch problems
  120. one more "3VZE - *Cali* smog thread"
  121. 3VZE Cranking wont start
  122. can you use a tie rod end after you remove it?
  123. 22re timing cover use it or lose it?
  124. Interior lights
  125. No fuel to start......
  126. 4x4 indicator switch
  127. 318ci V8 &5 speed swap into 2wd pick up
  128. Steering Box - Repair or Replace?
  129. Rhythmic hum a la "Living on a Prayer"
  130. 86 Pickup Buildup/SAS
  131. Injectors not working??
  132. Rebuilt 22re coolant in intake
  133. 95 4runner v6 3.0
  134. Newbie need A/C, found donor truck
  135. How Rear Roll-up Window Works
  136. engine swap 2lt 1986
  137. Suzuki Axle SAS
  138. advancing the timing on 3vze
  139. 94 Extra cab rear window power conversion
  140. 3.4 swapped 2nd gen rough idle
  141. 22re overheats while driving cools on idle
  142. tire size/loadrating and gearing combo question
  143. 3VZE valve shim source?
  144. Intermittent hard start, and bubbling coolant after shut down.
  145. Which NGK Plugs for 1987 22R
  146. Valve adjustment 3VZE V6
  147. Brake line problems
  148. Recent rebuild was running fine, now its rich
  149. Aftermarket Water Temp Guage Question
  150. 1994 V6 4Runner issues after timing belt replacement
  151. Valve cover replacement torque wrench ??
  152. Any tips on cleaning up intake mating surfaces 22re?
  153. 2nd gen rear spoiler or wing & swing away spare tire holder
  154. Turn motor for valve adjustment 3VZE
  155. Model number not listed in this long list of #'s. Will the part still fit?
  156. Anybody have one of those cheap chrome front bumpers?
  157. Oil in coolant fresh engine!!!!!
  158. 2L or 2LT?
  159. 86 22re into a 89 truck
  160. 1993-1994 2wd vs 4wd bed?
  161. early 22r to late 22re swap help
  162. Jumped Diagnostic TE1 to E1, spark, now no start
  163. My 1986 Toyota 2lt diesel pickup has a power issue
  164. 22RE I revved my engine up and check engine light came on and now won't start
  165. What years parts will fit 91 Pickup?
  166. 85 4 runner reverse gear
  167. Only with a Toyota
  168. 87 4runner coolant leak
  169. Crank no start after a new head cylinder, 91 pickup 4wd
  170. Problem with new injectors 3vze
  171. 22RE Isn't Breathing Correctly - Any Ideas?
  172. No Turn signal on a 86 4runner
  173. 1987 4runner Turbo throwing 6-1 code on transmissioni
  174. Replacement Interior Parts for 91 Pickup
  175. Need some help
  176. Changing AC compressor 1992 4runner
  177. Lock nuts for downpipe to manifold.
  178. Upper Control Arms
  179. '88 pickup fuel problem
  180. Can't Find 2WD Pitman Arm!
  181. intermitant and hard starting
  182. CV still binding after Diff Drop with OME Lift, BJ Spacers,
  183. Stumped: Pinion Seal, Rear Diff
  184. 99 4Runner
  185. 99 4Runner
  186. Easy cold start but Hard Start After Sitting Several Hours
  187. 22re Rebuild Write-Up; 1990 Toyota Pickup DLX
  188. T4R first gen power mirror switch
  189. Leaf spring questions...
  190. 22RE A/C Question - ORing Sizes
  191. Parts prices
  192. DIY Aluminum Roof Rack Build
  193. 3vze coolant leak battle
  194. Toyota 1994 4x4 Pickup project for the Sierra Madre Oriental Mountains
  195. 1990 Toyota Pickup 3.0 Roadtrip
  196. ecu pinout location
  197. HELP: mystery stalls/no starts - ICM?
  198. Temp Gauge Going Wacko
  199. R150F Shifter Compatibility
  200. Surging/ high idle
  201. Surging/ high idle
  202. Lspv help
  203. Bad O2 sensor causing miss - is my header eating O2 sensors?
  204. Headlight switch,brights only
  205. Help where is the mate to this plug
  206. 90 Toyota 4x4 5 speed, blinker issue
  207. Which temp sensor
  208. 4runner rear patch panels available today
  209. 93 auto runner trans problem
  210. oil pan removal on 1-ton FWD pickup
  211. 5 Spd interchange
  212. T4R first gen 22Re noises from fan
  213. 94 pickup squealing when accelerating
  214. Swapping the Combo switch 86 T4R to 88 T4R
  215. Where can I find an OEM 95 Pickup Rear Bumper
  216. head gaskets
  217. AT check : running or not running ?
  218. Head Gasket or Throttle Body coolant bypass?
  219. 93 4Runner Window Relay Location
  220. Wheel Offset
  221. Loud Ringing noise at idle ?? (With video)
  222. Tips for upgrades/fixes while the head is off; 1990 4cyl 22re 4wd
  223. remove ring and pinion in 93 toy
  224. new clutch fail
  225. Sludge in intake manifold
  226. 92 4Runner V6 Hard Start Hot
  227. 2 stage 22re thermostat
  228. Sluggish acceleration at start
  229. Looking for clear taillights (212-1977PCB-X1)
  230. Another 3VZE cold start issues - Fuel side is good -Weak ignition? Low compression?
  231. locking hubs
  232. Catalytic Converter
  233. Driveshaft Length
  234. throttle position sensor
  235. want to buy a scanner for a 96 Hilux
  236. 1986 pickup 2wd tank capacity
  237. 91 3VZE Power steering
  238. 22re rattling noise when under load
  239. Clicking
  240. Intermittent no start on 3.0
  241. Noisey Steering Wheel when turning after alignment 87 4Runner
  242. Using Leak Stop in Power Steering System
  243. 93 2wd 22re help needed. I had a blown head gasket on the original 22re.
  244. Manual Trans and leaky rear diff
  245. Oops what did I do, spacer/washer fell into gear shifter hole
  246. Just bought an 88 SR5 4Runner in great condition
  247. Thinking of Ressurecting My ‘84 Xtra Cab: Axle Question
  248. Deck lamp and dome light harness
  249. 91 3.0 intake problem?
  250. What to weld first? Newbie welder
