What is this plug?
Old Jun 15, 2018 | 01:57 PM
tgell001's Avatar
What is this plug?
I pulled the upper intake plenum off to replace the injectors and there's this random plug I don't remember disconnecting and it wasn't in any of the pre dissassembly pictures... Pics are here. First one is a far away and second is a close up
https://photos.app.goo.gl/cPg7hSRifSSus2KD7
https://photos.app.goo.gl/BTNMrsVoH1jqxHnu9
thanks in advance.
Old Jun 15, 2018 | 02:05 PM
thefishguy77's Avatar
Cant see the pics. But I remember there are a few that were not in use on mine when I got it. And it was dealer maintained before me.
Old Jun 15, 2018 | 02:07 PM
tgell001's Avatar
wonder why the pics links arent working. Huh? Well there are 4 yellow plugs at the fuel injectors and a green one that's on the same harness just dangling
Old Jun 15, 2018 | 09:55 PM
Co_94_PU's Avatar
Make, model year, package.. All details missing from your post..
At a glance. It was never connected (notice it's "memory", lays it pretty much right where you show it), likely the Cali spec emissions harness and that would plug into the egr temp sensor on the back of the plenum if you had one..
If you want to be certain you need to backprobe the ECU untill you find what pin(s) that plug has continuity with, then cross reference with the ECU pinout map.
Old Jun 15, 2018 | 10:39 PM
maco35's Avatar
Seems like it would connect to the Idle Air Control Valve if it's an early 22-RE.
Old Jun 16, 2018 | 02:46 AM
tgell001's Avatar
Sorry, it's an 86 22rec 4runner.
Old Jun 16, 2018 | 04:37 AM
RAD4Runner's Avatar
tgell001,
Welcome to the forum.
Yes, please always tell us what model-year-engine-transmission-trim you have. Else we assume it's an Escalade
If it's your only Toyota, I suggest you put info ^^^ on your signature.
Hot-start (Fuel Pressure-up) VSV?
Note how pressure goes up when I unplug it.
https://photos.app.goo.gl/BMw3Lp87NvpQhLFs5
4Crawler eliminated his (here)
Hurry, get done in time to run topless for the summer
Old Jun 16, 2018 | 04:43 AM
tgell001's Avatar
Sorry about the lack of info, i need to use a computer to set up my profile but I'm scrambling to get this thing ready for an event I'm leaving for Thursday.
​​​​​​But, that connection is terminated (see pics) I'm thinking it was never connected
https://photos.app.goo.gl/L4CdhH1hdgrcew1C9
https://photos.app.goo.gl/LXCSWFqpP7mHX9EVA
Old Jun 18, 2018 | 04:56 PM
wallytoo's Avatar
your pic links aren't links. you might get more help & info if you posted them as links, so that potential helpers could see them without having to copy/paste.
Old Jun 18, 2018 | 05:28 PM
RASALIBRE's Avatar
The blue connection in the second pic is for the IACV idle air control valve. There’s 5 ways I know of dealing with a bad IACV.
1. Remove it, clean it, test it, if all good, reinstall it.
2. Delete it, deal with overly rich, bad cold starts.
3. Find a good used one.
4. Update throttle body and upper intake manifold to an 1989 or newer.
5. Use a Nissan part as seen here:
View this post on Instagram
TRD83Yota4x4
Dec 12, 2011 11:45 PM
jentzschman
Aug 20, 2008 01:38 PM
Guardian_Saint
Dec 14, 2006 11:53 AM
JamesD
Jul 19, 2006 09:10 AM
