22re timing cover use it or lose it?
Old May 27, 2018 | 07:58 PM
outdoorjunky's Avatar
5 Year Member
So here I am discovering more jenkyness about my existing parts. Looks like part of the timing chain guide that's molded to the casting snapped off at some point ... I didn't find anything in the cover or oil pan as far as fragments of aluminum but it's possible I did this when taking it off not 100% if it was prexisiting or not.
Anyway I know some guys will reuse the cover even if the chain etched into the surface of it so I'm wondering how mission critical is this little section of aluminum that snapped off? The cover isn't cracked it's just that part that broke off ... see picture.
I'm leaning on the side of buying a new one but I'm already having to get a new intake and upper chamber and this whole rebuild is beginning to go over budget. If I can save a few bucks by reusing it I will assuming it's not going to cause issues. It's kind of a pain in the the you know where to get at after the fact.
Old May 28, 2018 | 08:41 AM
thefishguy77's Avatar
Do you have access to a high power magnifier of sorts. You could take a good look for cracks that way.
Old May 28, 2018 | 12:01 PM
millball's Avatar
If that little nick is all that's wrong with it, I'd use it again.
Old May 28, 2018 | 12:22 PM
5 Year Member
it it appears that the tiny little section of the casting and a scratch that you can see to the right side of the image is all that's wrong. I think this was my fault. I tore this engine down to the block because of a head gasket issue but then I diagnosed rod knock and other issues so it became a full rebuild. The head was already off when I was trying to get the crank bolt off and I busted one of the prongs off my pulley holder and I think that's when the chain bunched up down there and busted the tab off. That crank bolt was a real SOB to get loose, I ended up having to wedge a screwdriver through the pulley and resting against the timing cover where the timing degree marks are located...I still busted a screwdriver in half as well.
Old May 28, 2018 | 07:20 PM
SENOR NOODLES's Avatar
that part help s with holding the timing chain to the crank gear when doing head gaskets, it stops the chain from dropping off the gear. . Most of it is still there. I wouldn't worry.
Old May 28, 2018 | 08:40 PM
5 Year Member
got yah! thanks for explaining I appreciate it.
rustypigeon
Jul 13, 2016 12:18 AM
BUSINESS808
Jan 15, 2011 08:46 AM
yayfortrees
Apr 12, 2010 07:40 AM
ovrrdrive
Jun 20, 2006 05:20 PM
