want to buy a scanner for a 96 Hilux
Old May 1, 2018 | 01:58 AM
Kevin B's Avatar
I have a 96 Hilux Surf that was manufactured in Japan The manual is in Japanese Any way to translate into english? The check engine light came on and the truck stalled out . I need to buy a scanner but cannot find one on line It's the same connection as posted by Rom
Old May 1, 2018 | 06:12 AM
irab88's Avatar
Is it not OBD II? OBD II (OBD 2) scanners can be found on eBay for cheap, or many auto parts stores can scan for free.
edit: To translate: If you have a smartphone, there are apps that can translate using the camera. Some phrases might be a little off ("hot gasses" instead of "exhaust", for example), but you should be able to find what you need. I think it'll also work with Windows 10, the Microsoft translation app, and a webcam.
Old May 1, 2018 | 09:07 AM
RBX's Avatar
RBX
BTW.... regular scanners may not work on the early OBD2 Toyotas...
My 06 Hilux engine is OBD2 protocol: ISO 14230 (M-OBD ISO-9141) my scnner will not read this. however, Toyota was forced to comply with American sold vehicles after OBD2 was adopted, but I am not sure when.
you will have to search the interwebs for the OBD2 protocol, then find a scanner that can read it.
found this:
https://www.zasttra.com/pages/list-o...patible-toyota
BajaRunner
38
Jun 22, 2010 09:17 AM
NG Crawler
9
Mar 28, 2007 03:40 PM
