Catalytic Converter
Old May 1, 2018 | 12:19 PM
GorgeRunner's Avatar
Catalytic Converter
I have a 1990 Toyota pickup that needs a catalytic converter. It was purchased in California with CA emissions but is not registered there. Can I use a non-CA catalytic converter and not have problems like the check engine light coming on? Big difference in price.
Old May 1, 2018 | 12:37 PM
SENOR NOODLES's Avatar
Only difference is the cat has met California's quality restrictions. Which means they paid for an exemption order number. Run either one. The second O2 sensor is just a cat efficiency sensor. It does not adjust fuel trim. So even if the CEL comes on for cat efficiency, it will not harm anything (unless cat is clogged) or the environment.
Old May 1, 2018 | 05:52 PM
old87yota's Avatar
I am not 100% sure, but running the non-C.A.R.B. converter should be just fine. Like SENOR NOODLES said, the oxygen sensor after the converter is just a monitor that checks if the catalytic converter is working.
Old May 6, 2018 | 01:18 PM
I don't want to put in a new catalytic converter and have the engine check light come on for the effort.
Old May 7, 2018 | 07:41 PM
Took off the old catalytic converter and discovered I bought the wrong one. Punched a hole in the old one and put it back on. No check engine light yet.
jrallan26
Feb 10, 2004 02:01 PM
markjs
Jan 19, 2004 12:57 PM
Mindburnt
9
Sep 7, 2003 08:53 PM
SoL
37
Jul 10, 2003 10:48 AM
vudbster
Jun 11, 2003 07:43 AM
