PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 [154] 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. bear river off-road course?
  2. hydraulic clutch problems!
  3. Where to buy battery terminals with multiple accessory attachment points?
  4. weird brake pedal in low traction conditions
  5. Rebuilt 90 3VZE #3 oil fouling. Help
  6. 88 22r Starting Problems
  7. new shoes...
  8. Front Disk Brake Caliper Pins Part Number?
  9. Head Gasket
  10. Santa Rosa, CA Pick-N-Pull, '89 Pickup with 4" ProComp Bracket Lift
  11. 3vze first timer
  12. The best birfields?
  13. Fan shroud question
  14. Starter? Battery Terminals?
  15. rearend wobble from one tire
  16. ECM Failures
  17. 93 toyota
  18. New Addicted bumper
  19. Power question
  20. pulling tranny in 95 runner
  21. clutch master cylinder problem!!
  22. 5 speed swap is done!
  23. FJ80 Land Crusier Coils
  24. Shackle or blocks?
  25. bezel
  26. 1994 4x4 P/U 22re
  27. Driver's side handle mod retrofit
  28. Lower mainland engine rebuilders
  29. 22re vacuum hoses help!
  30. Atten all 2 gen truck owners, Want a Bedrug? please help in getting one made..
  31. sport seats from 1986 as compared to 1987.. any diffference?
  32. what the heck size of lift is this???
  33. Need a measurement and AC question.
  34. 1986 Toyota 4wd project
  35. 4runner trade??????
  36. electrical issues
  37. drive shaft
  38. 1990 4Runner No Compression V6
  39. Idle problems
  40. engnbldr 22re head installed now questions
  41. Question about '91 4runner...
  42. electrical issue please help!
  43. 3vze head gasket mystery
  44. drive line blues
  45. Rear window fun
  46. is a rear Smittybilt bumper stronger than stock?
  47. First Gen A/C Parts Question
  48. 1st Gen Top Storage
  49. Spindle lubricator
  50. oil gauge question
  51. New guy with 22RTE ?s
  52. AFM adjustment
  53. 47322 another toy. part number i didnt want to know
  54. weird 22re problem....
  55. need URGANT help with distributor
  56. Need A lift
  57. Need help electric fan not working.
  58. 1990 4runner SR5 need help please!!
  59. Charging system?
  60. High flow oil pump?
  61. 2nd Gen electric fan install
  62. Advancing Cam Timimng..need help?
  63. 3inch body lift ideas help me find the right one
  64. 15x7 4.5 BS?
  65. Show Your Best Flex...
  66. 90 pickup while its idleing foam start bubbling out the radiator
  67. Exhaust valves need adjusting every 5k???
  68. Sweet 22re music
  69. The 2dr 2nd gen 4skinner
  70. 94 pickup hood
  71. A/C help
  72. How To Set up the Fuel Pressure Tester? 92 4Runner
  73. Bed Patch Panels.
  74. Looking at getting a Toyota pickup
  75. Update -- Why Crank didn't turn when finding TDC
  76. Engine Rebuild Kits
  77. 22r to 22re swap help
  78. power steering cap..
  79. Pics of throttle cable bracket and more
  80. 93 3.0 auto gutless and sputtering running out of ideas
  81. 3.0 Over 200k
  82. Resonator box removal?
  83. 22RE - Surging Throttle
  84. '94 22re remove egr what all to take off
  85. 22RE Engine Rebuild Tips
  86. differences between 22r and 22rte
  87. Front seal leak
  88. toyota 92 v6
  89. Toyota 4.88 gears
  90. 88 pickup bumper
  91. Heater fan
  92. 87 - 22r TDC with head off ??
  93. Weird thing happening 1987 toyota pickup
  94. What Year 3VZE Motors are the same??
  95. 874runner-94pickup
  96. I need more leg room!
  97. Issue?? Vapor Lock??
  98. 22re water pump bolt length?
  99. Painless wiring kit for truck
  100. Single T-Case Crossmember?
  101. help! please 94 pickup
  102. Hesitation and surging problem
  103. Towing Capacity Question..
  104. opinions on motor swap
  105. 1" coil spring spacer?
  106. Motor swap
  107. Opinion needed - Repair shop wants to replace my A/C Amplifier
  108. Moog Idler Arm
  109. 92 Pickup Universal joint/Driveshaft removal
  110. Problems with my newly installed 22re, it hardly runs
  111. new master, bled out and still bad pedal and poor brakes, what next?
  112. low idle and water disappear
  113. Rear spring hanger off by a 1/4 inch??
  114. Truck Went in For Out Of Province Inspection........
  115. Marlin Shifter Seat Questions
  116. 5 speed swap on a 87 runner~
  117. new too the 4runner
  118. Help with another rusty frame
  119. interior pieces
  120. sticking throttle pulley
  121. ??? about my 88 22re truck
  122. speedo, OD n cruise
  123. Hella 700ff installed, of course there is pics.
  124. LCE Exhaust..
  125. hard start issue
  126. Starting Problems
  127. wiring up in flames........
  128. Computer sticker question......?!?
  129. Replacing Lower Control Arms '94 Xcab
  130. Source for remanned/rebuilt 22re?
  131. intermittent CEL code 72 and starting
  132. charging problem.... with no charge light
  133. 94 22re intermittant engine problem
  134. Rear Rims are very hot.
  135. another rear window wont work propblem
  136. 92 4 runner ac amp diagram
  137. Weird metal on metal sound while turning
  138. protecting the t-case without buying a new cross-member?
  139. 1990 22re does not like to idle sometimes???
  140. 3RZ ECU and Harness for 22re?
  141. Name that hose!
  142. 87 4Runner somtimes has all idiot lights on
  143. Oil pressure port size- 22re
  144. ignition timing for 1986 22RE
  145. Factory Alarm????
  146. weird starting problem
  147. Addition priorities?
  148. Help! Very strange transmission problem
  149. Svp?
  150. VSV switch
  151. Surface Mount LED Backup Lights - Thoughts?
  152. Solid Lifter adjustment required- Or Heavy OIL
  153. 94 toyota pickup
  154. 1990 22RE Motor Mount
  155. 94 4runner fuel system problems
  156. High oil pressure gauge readings
  157. sr5 graphics/stripes q's
  158. Overheating Help!
  159. Coiled SAS
  160. ram air idea
  161. Do I need shims? if not what do i need?
  162. Clutch Feel (or lack of)
  163. 22RET- time to upgrade
  164. main fuse blowing. charge problems
  165. 1" rear coil spacer?
  166. 22re motor knock
  167. No spark
  168. Help - 88 4runner Maintenance - 3.0 Lts
  169. I did a vacuum manifold test and need some help
  170. 22re exhaust manifold help?
  171. Went out to lunch and came back with a motor.
  172. 93 4x4 Truck Vibration Issue at 50 mph
  173. tie rod problems
  174. v6 gears
  175. Shocks preference
  176. AC compressor pulley
  177. Still have strong fuel vapor smell 90 3VZE
  178. R150F problem
  179. Wiring Diagram explanation
  180. Couple pics of my 90 4Runner
  181. question about brakes
  182. regearing questions!!!
  183. Check engine light
  184. little bit of rust...
  185. 22re help, hard to start, runs great once started, codes 8 and 27
  186. defroster vents.
  187. Using a Hi-lift.
  188. Gear oil frustrations
  189. I need to know the name of this 22re sensor
  190. FREE Drivers Side Bed Panel
  191. My CLEAN DD
  192. Help 95 4runner auto v6 with 33's cant accelerate over 65mph
  193. Cant figure out my Cruise Control - HELP!
  194. short ram intake Help!!
  195. Got meh new tires on!
  196. anyone else have this dash problem??
  197. Exhaust Misfire Video
  198. Head Bolt Helicoil
  199. 1988 gmc sierra original trans?
  200. UHHHH OOOO!!! air box filled with oil!!
  201. 90 22RE Seafoam treatment
  202. High RPM Problem
  203. Post bj spacer alignment prob
  204. Rear Bumpers off of diff trucks?
  205. figuring out what trans?
  206. EFI Fuse keeps blowing!
  207. Installing new End Links - help
  208. wiring harness differences
  209. 4wheel drive problem
  210. Bad Smell
  211. Troque Converter,Crank Pulley
  212. New member to the board!!
  213. 22re intake manifold leak
  214. Good place to get an 02 Sensor
  215. 1993 truck door jamb sticker information needed
  216. Low oil pressure on reman 3vze
  217. 1986 22RE Head Gasket Replacement
  218. windsheild trim removal
  219. Code 25...Looking for opinions
  220. New tail lights on a flatbed help
  221. motor will not start then it will blow out of the carb
  222. fuel computer/management
  223. Replacing Pitman Arm +???
  224. 88 4runner PS door wont open
  225. Finish my 3.0 HGs....?
  226. new starter?
  227. Leaking coolant hose fixed, but what does it do?
  228. Anybody have a 3VZE that starts good everytime??
  229. 1995 3VZE- rough idle, stumbling, lost power
  230. New to me 90 22RE 5spd 4X4 95k miles
  231. Cadillac Horn
  232. New 4runner pictures
  233. Thing on top of the valve cover (picture)
  234. ARB Bull Bar on 1989 4Runner - Install Question
  235. Steering Valve body. -What does this do?
  236. cylinder heads
  237. Custom storage box, need to color match vinyl
  238. SR5 Cluster swap
  239. new oil leak
  240. 1990 4X4 Front rotor replacement
  241. Taco lights on a 4runner?
  242. Pulling codes on a 92 V6 4x4
  243. 1994 22re Wiring Diagram
  244. Truck in pieces!
  245. Weird sputtering problem, 22RE
  246. 22re engine noise
  247. 86 4runner pics with Bikini!
  248. need part name or how to find a set!!
  249. spectre intakes on 22re
  250. Need Help w/ Preventative Maintenance
