Missing Fuses?
Old Aug 12, 2009 | 07:53 AM
Cptchunky's Avatar
Missing Fuses?
Ok I am probably wrong but I think I am missing some fuses I searched around looking for an image or something that would show me the fuse layout because my truck doesn't have one. So I am just checking to make sure they are all there and accounted for. Its a 88 3vze 4x4
Thats the man Fuse panel under the hood.
Thats the Diagnosis fuse thing Im not too sure what that stuff is inside of it was like that when I got the truck
That one had IG- on it not sure what it was for but thought Id throw it in anyway
Also I forgot to take a pic of the fuse panel inside the truck so if someone can tell me which ones I need there or take a pic of theres so I know.
Old Aug 12, 2009 | 08:03 AM
Lumpy's Avatar
There may be some open spaces for fuses...What is not working in the truck? Is it not running?
Old Aug 12, 2009 | 08:09 AM
Cptchunky's Avatar
Its not running Im in the process of changing the timing belt then I am goin for the plugs and wires. It sat for bout 10 years in a field behind a guys house so its been awhile since it ran lol. Just wanted to make sure none of the fuses went missing while it was sitting there.
Old Aug 12, 2009 | 08:29 AM
Lumpy's Avatar
The diag is just for that...you use a small wire to jump the terminals to get the error codes...http://www.troublecodes.net/Toyota/
As far as the fuses go...You might be missing 2 of them #3 and #6 Not rightly sure what they are for...
Old Aug 12, 2009 | 08:43 AM
Cptchunky's Avatar
Yea I got the codes already its just one its a code 51
Old Aug 12, 2009 | 08:50 AM
TNRabbit's Avatar
Knock Sensor, if memory serves...most likely the pigtail instead of the actual sensor...
Old Aug 12, 2009 | 08:52 AM
Cptchunky's Avatar
Ah ok I went to that website he linked and all it gave me for 51 was Switch Signal. Wasnt sure what that ment
Old Aug 12, 2009 | 08:57 AM
TNRabbit's Avatar
You're right; my bad.
Old Aug 12, 2009 | 09:00 AM
Lumpy's Avatar
52 and 53 are the knock...you were close. I'm not sure what switch though, ignition maybe???
Old Aug 12, 2009 | 09:04 AM
Cptchunky's Avatar
I have no clue lol hopefully I can get this timing belt finished up soon and get the wires and plugs changed so I can give it another trying starting up.
**edit** I just saw 14 is ignition
Old Aug 12, 2009 | 09:10 AM
Lumpy's Avatar
Well get her back together and double check all your connections (that you can see and find) and we'll take it from there. Be sure to unplug and plugin all that you can, may have a bad connection somewhere.
Sleaker
Aug 26, 2020 06:03 AM
theking11863
Mar 19, 2016 09:36 PM
izzmee
Aug 17, 2015 10:20 AM
Mrhoadley
Aug 4, 2015 06:08 PM
rushw
Jul 18, 2015 01:46 PM
