v6 gears
Old Aug 16, 2009 | 01:02 PM
93YotaMonster's Avatar
v6 gears
hey guys will v6 gears fit in a 4cyl 3rd?
Old Aug 16, 2009 | 02:01 PM
toyNG's Avatar
I know that the 4.88 gears from a factory V6 will not swap into the 4cyl 3rd. But I'm not sure about the other gear ratios.
Old Aug 16, 2009 | 03:02 PM
sas'd22re's Avatar
you cannot put v6 gears into a 4 cyl carrier, but you CAN put 4 cyl gears in a v6 carrier
Old Aug 16, 2009 | 03:11 PM
toyota4x4907's Avatar
or you could just put the whole v6 third into the axle housing...
Old Aug 16, 2009 | 03:19 PM
well i sent zuk a pm and he said that you can swap v6 gears into a 4cyl 3rd.
this is what he sent me back.
(Ya....did you know that your 22RE 94 has V6 gears in that 4 cylinder 3rd? V6 pinion heads are longer...so the key to making them work is a "shorter inner bearing" so use the oem 90366-35044-77 inner bearing with a 4 cyl carrier.)
Old Aug 16, 2009 | 08:47 PM
Stuwy123's Avatar
V6 carrier will fit in the 4 cyl axle housing.
I swapped a set of V6 4.56 diffs into my 4 cyl truck. No problems or modifications needed. Drop in mod.
Old Aug 17, 2009 | 06:17 PM
ZUK's Avatar
ZUK
Hey Yotamonster-
Just coincidentally, I just now received this info from the guys at http://justdifferentials.com
http://www.nitro-gear.com/articles/
They are dis-continuing "4 cyl" gears in the Nitro line and selling only the "V6" versions. Note that calling them V6 gears is a bit mis-leading but all it means is they have a thicker or longer pinion head. ZUK
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
