What Year 3VZE Motors are the same??
Old Aug 19, 2009 | 05:53 PM
zbadboy
Guest
Posts: n/a
I have a 94 with the 3vze motor. I have a parts donor truck that supposedly has a 92 3vze motor. The only visual difference I can see is the thermastat housing coming of the front of the motor has an extra cooling line that runs to the back of the motor under the intake manifold. Any Idea what 3vze motors fits what years? The Donor is a Auto and mine is a manual. I do not think that makes a difference. I did compare the donor truck to a 94 3vze with auto and it did not have that extra hose either. Any help is appreciated.
Old Aug 19, 2009 | 07:06 PM
yoterr's Avatar
their might be slight variances between the 2 for emissions reasons, should work otherwise its not a huge year gap and i think there all pretty much the same anyway
Old Aug 20, 2009 | 01:51 AM
TNRabbit's Avatar
The main difference is the ECU for auto/manual--you'll want one with same tranny. the extra cooling line was on the towing package option trucks and goes to an oil cooler on the side of the block under the exhaust manifold.
Old Aug 20, 2009 | 05:08 AM
blueyoda's Avatar
I have put an engine from a 90 auto into my 91 manual and I am doing the same thing for my 95 as well. There were no problems, you do not need an engine from a manual as the extra sensors at the back of the intake will not get connected to your manual ecu. Just make sure to lable the vacuum lines as they can be a PITA to get back in the right spot. Good luck, I am doing the motor swap now as well so ask away if you have any questions.
Old Aug 20, 2009 | 06:51 PM
zbadboy
Guest
Posts: n/a
Thanks for the answers. I have to decide to spend the labor time on a used engine vs a new one. Blueyoda thanks for the offer for assistance.
Old Aug 20, 2009 | 10:28 PM
mick cassidy's Avatar
HEY i need the same help i bought a spare motor looks really clean from these japan importers here in la i was a auto matic i can tell from the flex plate attached to the crank but there is a few small differences , i will post some pics when its gets bright tomorrow hmm both motors have that round oil cooler but the smog stuff looks a little different and the fuel inj harness .. but the block id say has 40 k max i paid 1400- for it
ill post pics tomorrow night
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
smiley52
Jul 11, 2015 05:16 AM
AaronM
Jul 8, 2015 07:15 PM
