Pulling codes on a 92 V6 4x4
Old Aug 13, 2009 | 06:06 AM
dem0nk1d's Avatar
So my check engine came on today. I tried pulling codes and nothing on the dash is flashing. Isn't the check engine light suppose to flash a certain number of times? I have the service/diagnostic port jumped with a paper clip, and nothing is going on. Can anyone shed some light on this...
Old Aug 13, 2009 | 06:17 AM
abecedarian's Avatar
Sometimes the paper clip trick doesn't make good contact with the terminals so you may want to use a short piece of stranded wire or find crimp terminals, to put on the end of a piece of wire, that fit into the terminals... I believe it should be flat/blade type connector 0.125" wide.
Also, don't start the engine- just turn the key on. (Not saying you did this but....)
Old Aug 13, 2009 | 06:24 AM
dem0nk1d's Avatar
yeah i can't tell if it's making a good connection because of the electrical grease toyota uses. I'll give that a try. I was thinking about taping into the wires and adding a on/off switch.
Old Aug 14, 2009 | 07:58 AM
dem0nk1d's Avatar
maybe i'm using the wrong connectors. can someone please clarify which pins to jump on the diagnostic connector.
Old Aug 14, 2009 | 09:02 AM
TNRabbit's Avatar
Jump TE1 and E1.
Then turn the key to "ON", count the number of flashes, including any pauses (two separate codes, then repeat)
Old Aug 14, 2009 | 09:24 AM
dem0nk1d's Avatar
yeah that's what i thought.
some drunk guy
Aug 3, 2021 06:09 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
Armstrong486
Sep 19, 2015 12:37 AM
