- Clogged EGR Valve = Poor Idle 3VZE
- White smoke prevails after new head gaskets - 3VZE.
- Cowl Vent Covers - keeping the leaves out
- Repairing interior on 92 4runner
- Crossover steering rubbing leaf springs
- 3vze blown head/worth fixing?
- Replacement o2 sensor - engine light
- Lifespan of 1986 SR5 with 22RE
- fuel injector rebuild
- 22re and v6 gear ratio and more !
- What makes 2nd gen 4runner special? If it is..?
- Camshaft seal?
- 93 Toyota Pickup 22RE Will not Idle
- bed bolts 88 pickup
- 4.56's from Automatic '90 into Manual '95 w/ stock 4.10's?
- Speedometer Cable Jitter Bugging
- Please help with 1992 22RE Flooding issues
- Im back!
- Need help with part #
- 86 pickup with uncontrollable bump steer.
- Should Cold Start Injector always receive signal?
- 92 V6 Valve Cover Gasket and Intake Questions
- No go in gas pedal
- New AFM, Timing Issues
- 1990 4Runner v6 wont start when warm
- Dash Carpet - where to find?
- 90 3VZE starting issue
- Newest addition to my yota fleet
- rebuilt 3.0 poor mpg and power surge
- 3.0 intermittent no power after idle with a/c on
- Need Repair Cruise Control 1986 Toyota SR5 4WD
- Seat Belt Replacement for 1986 SR5 4WD Needed
- OEM Parts from Overseas
- 89 3vze, cannot check timing, timimg mark bounces around
- New User, Old Truck: 1988 4Runner Build
- alternator pain in my !!!
- Suspension lift kit??
- Engine will not turn over
- 93 4. Runner transmission problem
- 1993 4-Runner 3VZE
- Dash lights, help please!
- Review - Dorman C94127 - Rear parking Brake Cable (T above axle)
- 95 4Runner cranks but won't start
- 93 4runner transmission problems
- Russian made diff's.
- Does AFM harness connector look like this?
- birfield eliminator kit
- WTF Now
- 93 Runner, 3.0, Crank, Won't Start
- 1990 4 runner 3.4 swap automatic
- Ignition Switch pins
- Timing Mystery
- [HELP]No fuel pump priming but fuel pressure is there when startup!? (video)
- engine code 6, truck runs fine.
- Pitman arm nut
- 1993 toyota pickup 22re wont rev past 3500rpm
- Pickup Hard Shifting
- WANTED: 3vze CORE from Seattle to Portland
- MPG with 86 xtra cab Long box 2wd
- Engine dies if I plug the vac advance hose
- 92 PU: HVAC light is On/Off
- CV Axle bind?
- Torsion Bar/lift questions.
- transfer case shifter bushing
- 4X4 issues
- 3.4L cross over pipe on 3.0L? Thinking outloud
- $100 rust-oleum paint job
- Help me identify where this connector goes!
- Vacuum woes, 93 pickup 3vze
- 22RE Performance Engine - Jim Putney
- Is my timing belt slipping? (Pictures)
- 88 transmission swap into 92 4Runner sensor question
- 93 Pickup with a funky idle...
- Trying to set timing hut engine dies
- LCE Pro Flow Exhaust System
- 3VZE No-Start Question: Got Spark, Got Fuel
- New to the site. Hello and Thanks!
- new PS pump, really tight steering
- Score
- New project
- Vacuum Hose Question - 92 3VZE
- 3vze No power&slow rev ups(videos) HELP..
- Severe drivetrain shudder under load
- Help on choosing engine changeover for my '87 4Runner to 8cyl!
- No power to gauges or heater fan 22re?
- No newb but need help
- Check engine light o2 sensor - help
- Shifter seat bushing
- Vacuum Switching Valve Broke
- Knock sensor
- Am i reading the fault codes right?
- need some advice
- 1993 Toyota pickup 3.0
- need help with the 3vze
- Engine turns over once before starting?
- Dream truck-86 4Runner build
- Removed distributor without setting engine to TDC
- 86 Pickup Lift.
- Blew HG at 140k on '95
- Getting her dialed in
- 92 Pickup no power to AC
- 91 4runner 3.0 Acceleration issues
- Broken bolt, could use some guidance.
- will 89-95 truck fenders "fit" on a 84-88 body?
- Interchangeable parts ???
- Help finding dust cover part
- Battery and brake light always on
- LS/SAS/BJ60/HighSteer - oil pan interference
- Locker unlock brainstorm
- Trouble removing heater fan switch 1994 pickup
- Testing Ignition Control Module with a multimeter
- 1987 4x4 Trailer Reciever
- Parts suppliers
- 4Runner Canopy Questions
- Fuel Pump issue
- complete electrical failure of a '92 Toyota pickup.
- 3vze surging idle issue
- Ecu problem SOS!
- wheels
- Best way to weld toyota sheet metal?
- Question for this electrical connector..
- Loose head bolts 22re
- Loose head bolts 22RE
- Control arm bushing replacement
- 3rd gen pickup transfer case
- 94 pickup 2wd Motor Blown 22re, Important questions Need Knowledgeable people!
- Jetting, Weber for 5,000 ft and up
- Milling the head 22RE
- HELP! Superpooch
- 93 Toyota reg cab. Clutch still losing fluid. Won't crack over.
- Uninstalling lift
- 3vze ps
- 1989 22r: poor idle and backfiring
- DT8000 vs DT3000 on the Front IFS, which shock?
- Noise On Downshift. Video Included.
- How do you remove this lock?
- LED Headlights - List of Truly Plug & Play Options
- 1987 conversion help? 22re to 2L diesel
- 3vze over fueling!!!!!!!
- Bolts on back of 22RE head
- wheel place ripping me off?
- New Build. Tapping noise and oil pressure light. Need Advice.
- Running without injector pintle caps??
- 87 4runner rear suspension
- Wildwood Combination Proportioning Valve
- I wish I knew about this a week ago...
- (22r Carb) Part name ? rough idle/shutting off
- #4 cylinder not firing
- time for an engine swap. opinions wanted!!
- Standard Cab Short Bed 4x2 vs 4x4 Fuel Tank Swap?
- 3VZE intake solutions after 7MGE VAFM
- 1987 22r weber swap throttle linkage problem
- Will timing be off?
- Dashboard Vents
- 1kz-te to 3vze transfer case swap
- 3VZE won't start after knock sensor replacement
- $300 89 4runner?
- HELP. (off topic) could not post under maintenance
- 91 4runner with 96 tacoma axle
- 22r carb throttle linkage pictures needed please
- OEM Rear Bumper Part Number?
- 22re won't start after engine swap
- Help in finding 86 4runner repair manual
- Removing Engine and need some help
- 22RE swap from '94 to '91 body
- 91 Pickup resonator question
- 93 Toyota 4cyl pickup stalling out.
- New Engine Break in. Has Knock.
- 85 efi motor in 86 carb'd truck
- 3VZE Cam Plug Retainer Debacle
- 22RE Stalls After Full Throttle
- Water in oil
- Accurate Engine Temp Indicator With Audible / Beeping Overheat Alert
- 1jz or domestic vortec 4.3, 4.8, 5.3?
- Oil Cooler hose question 3.0 v6
- Catalytic converter. Is it needed?
- Starts and dies...... HELP!!!
- AC vacuum lines HELP
- Efi surging mystery help!!
- Starter cranking with out key.
- Ivan Stewart's 4Runner Pre-Runner - Autoweek
- Fixing the grill.
- Silence is golden. disabling the buzzer.
- Water Temp Sender Location. 88 22RE
- Dash Wiring for accessory & marker light taps.
- Oil Pressure Guage.
- Trailer Wiring.
- Rock Screens
- Dash Removal/Heater Control Repair: Write UP-How to
- Yo yo shaving my head for HPs!? How much?
- Gm alt conversion not charging.. Any info is appreciated!
- How much lift am I rockin?
- 91 Pickup Bed Replacement
- Code 52 intermittent, and other oddities
- 22re pickup overheating
- Can't re-install crossmember
- 22re running rich when warm
- 22re 5 Speed pops out of reverse and sometimes gets stuck
- Auto Trans 86
- New to Toyota
- 300 dollar 4runner. What to do?
- Noise after water intake
- Truck Brakes Dragging
- Camshaft question
- Is my timing chain off by a tooth?
- Gas everywhere, in the intake, coming out the exhaust pipe, in the oil
- 95 4runner rear axle wont center (coils)
- 1987 4Runner manual leaking oil from transfer case
- Need help with oil leak from transfer case area
- Front diff/axle nuts
- Play in driveshaft - and not the u-joints
- help
- Need help!!!
- Hard starting 94 3.0 4x4 pick up
- Knock sensor issues
- All Japanese Classic Meet - Vancouver, Aug. 28
- Head gasket to get locally?
- Alternator Issues
- 22re blown swap 22rec
- Seeking to upgrade stock bumpers--need suggestions
- Efi circuit issues 1989 pickup 3zve
- 3vze timing belt help
- Rear suspension need some help
- 93 Toyota AC blower fan
- Newbie here! 1995 Limited
- Manual transmission: Suddenly no power to wheels
- 1990 wire harness and fuse panel
- Help!! Dropping new motor, oil pan sitting on diff!!
- Is there an A/C unit kit that can be installed onto a 1990 pickup 22RE?
- Replacing My 22RE Engine, What Else Should I Do???
- Installing shifter carrier retainer
- 93 pickup o2 sensor burned due to muffler
- Fuel Pump Issue 94 Toyota Pickup
- Speed sensor issue
- Set timing on 4runner that will not idle
- Side slider window rubber trim and 4runner emblems
- Cam removal and head cleaning
- 86 4 Runner timing chain bent valves?
- Differential size?
- Valve clearance 3VZE
- Trouble with my '86 22RE Turbo (High RPM/Slow roll)
- 3.0 Gear swap
- What is this dimmer switch from?
- Front Hub Bolts and Cone Washers
- 95 4Runner 3.0 starts and stalls
- Gen1 4Runner Matchbox Truck(s)
- Center console
- Extra pipes on the back of a new radiator?
- 88 4Runner tongue weight?
