93 4. Runner transmission problem
Old Sep 25, 2016 | 10:51 AM
jwilliamson0927's Avatar
Hi guys so I'm new here. I have a question regarding my 93 runner. So the other day I get in it and put it in drive and it will not go anywhere. I started trying to figure out what was going on so I put it in 4hi and it still did not move. But when I put it in 4lo it will go anywhere you want it to go with absolutely no slipping. I can climb hills and climb on top of big rocks with absolutely no problem. Does anyone have a clue as to what could be causing this. I changed the fluid and added Lucas transmission additive which did not help a bit. Thanks in advance guys.
Old Oct 4, 2016 | 03:30 AM
So is this a trans problem or a transfer case problem
Old Oct 4, 2016 | 08:09 AM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
This probably isn't much help, but what I would try at this point is isolate the problem, or try to. If it only goes in 4L (with any gear? Is it auto?) I might try pulling off the back drive shaft and see if infact it's the front doing the work. Maybe try looking at a FSM (they've got links to them on this forum) and seeing if I could see a common possible point of failure.
There's some smart folks here, but it might take a while for anyone to see your post. I've sub'ed to a few threads, and got off work this week, and no posts. Sad movie.
Old Oct 14, 2016 | 07:33 PM
Yes it is an automatic. I just feel like of it was the tranny slipping it would slip no matter what. Especially when putting it under a load like climbing on a rock. I have also looked at the FSM and could find anything that relates to my particular situation which is why I made this post. What ever is going on it has gradually gotten worse . It started out only not wanting to go on cold mornings last winter. Once it warmed up it would go fine in any range. But I have cha he's fluid and filter and added lucas tranny additive. Do yall ha e anymore suggestions?
stanz
16
Feb 5, 2025 01:09 PM
Jeremiah.js
7
Aug 25, 2016 01:00 PM
Tenn_Yota
Aug 9, 2016 11:09 AM
Rustyyota90
Aug 9, 2016 11:01 AM
chappell92
Aug 5, 2016 06:00 AM
