Getting her dialed in
Old Sep 14, 2016 | 01:29 PM
cbr600rx7's Avatar
So it's been a long project but I think we are getting there or maybe that's wishfull thinking.
So ever since we purchased the truck she has had a low throttle bucking issue. It seems to be most noticeable in 1st gear at low speeds and partial throttle. Today I leaned out the VAFM back to stock (previous owner had it turned 7 clicks CW{rich}) and the bucking seems to have gotten worse but the truck is idling smoother and no longer smells like fuel. I have base timing turned back to 12 degrees with +4 built into the cams and running 92+ octane and at highway speeds the issue does not present itself. I am pretty sure the issue is throttle body related and could be TPS. Any advice is welcome.
1995 4Runner 3VZE 5 speed 4.56 gears
Rebuild 3VZE
crower cams/LCE valve springs
7MGE VAFM With 3" ISR
2.5 exhaust
and so on.
Old Sep 14, 2016 | 02:41 PM
Turtl3's Avatar
Have u got a lunchbox locker in the rear?
Old Sep 14, 2016 | 03:33 PM
cbr600rx7's Avatar
Not that I am aware of. It should be factory open diffs (for now)
Old Sep 15, 2016 | 03:39 AM
cbr600rx7's Avatar
The issue seems more dominate when the vehicle is cold at low speeds in first gear. It's best explained as a low speed miss or stumble.
Old Sep 15, 2016 | 08:47 AM
cbr600rx7's Avatar
It will stumble considerably at 0-10% throttle at low RPMs. It's more noticeable when cold but also does it when warm.
Old Sep 15, 2016 | 09:19 AM
fierohink's Avatar
You can test the tps with a voltmeter to see if there are dead spots in the range. As well as check for smooth throttle plate movement.
Old Sep 16, 2016 | 04:00 PM
cbr600rx7's Avatar
Well we made a huge steep forward today. A friend had a extra manifold with throttle body attached and TPS. I swapped out the hole throttle body since it came off a running vehicle and sure enough the issue is gone. This throttle body had a toyota TPS sensor where the one that has been giving us problems was a cheap China made unit from rock auto that the old owner had installed.
Old Sep 16, 2016 | 08:19 PM
fierohink's Avatar
Knock off sensors do not work well in Toyotas.
As much as I hate paying dealer prices or factory prices, they never let me down when trying to eliminate gremlins. Bosch or Denso o2 sensors, denso MAF sensors, NGK plugs, etc.
dbbowen
Sep 23, 2016 04:57 PM
Brown T
Jul 4, 2016 08:06 AM
jbv808
Jun 29, 2016 03:51 AM
Mr. iNCREDIBLE
Jun 26, 2016 09:23 PM
cbr600rx7
Jun 24, 2016 06:11 PM
