- First 3vze timing belt
- rough idle, random misfires, and gremlins
- 1988 toyota pickup diff rebuild
- 95 4wd probs
- Tranny rattle on decel
- Hub / Spindle Grinding
- Something grounding out when hot?
- Steering hesitates when turning right
- Brake lights stuck on when headlights are turned on
- smitty built bumper ?
- Driverside water leak whe it rains
- rear disc brake research, keeping the e-brake idea
- 22re Bolt part numbers
- Clutch start cancel switch removal
- 3VZE overheats, not thermostat, no heat
- Automatic hubs on an '86 4Runner...opinion question...
- Welded rear on DD 4runner?
- LC EGR Block Kit & EGR Crossover Block Plate Questions
- Coolant leak and other issues
- thanks
- Low Dollar 4x4 Project!
- Huge MPG Drop!?
- need advice on best fixes for 1992 4runner 3.0 VZE sagging rear end
- 95 pickup rearend
- Help me make the right decision here.....timing chain goof
- Differences between t100 and 4runner 3vze?
- Should I Upgrade Injectors Along With My AFM?
- Swapping W56 into V6 4Runner
- SAS'ing 1st Gen 4Runner to stock height?
- transmission issues help plz
- bad sound from front end
- ball joint spacers
- 1988 runner 22re tranmission woes
- Strangest gas pedal problem
- Super strange timing setting
- 22re Boged Down
- two random hoses
- Engine Oil Leaking From Head and Coolant Leak
- how many miles do you get to a tank?
- 22re Running Too Cold- T-Stat?
- valve clearance issue
- '94 4Runner 3.0 stumbling/dying. PLEASE HELP
- Vibrations
- Introduction
- brake help 88 p/u
- 91' Toyota Pickup build keeping the rust away
- Sway-A-Way woes...
- Brake warning light won't go out (Charge light is fine)
- 1993 22RE poor fuel mileage
- Pulling a trailer with a 22RE 4Runner...?
- 87 22r Carb Problem, FLOODED!!
- 87 heat A/C control panel cover
- New 456's...need some clarification on the swap
- Lithium soap base glycol grease explained
- 87 pickup, comin' together
- Rebuilt 22re, timing woes
- A340F A/T dies
- sas pickup front end vibration
- ANYONE recognize this piece?
- Throwout bearing noise? (Video)
- 87 4runner complete rebuild running rich.
- Starter Issue
- Water temp sensor question
- Smells like propane
- Transmission Starter Bolts, Do They Go All The Way Through?
- Oil Pump Seal
- rear bumper
- swapping a 3.slow with a 22RE
- Rear diff cover.......
- i have some questions on swapping 85re for a 92re
- 91 Pickup runs rough while warming up
- injectors
- defroster is cold air, side vents are hot?? help
- 22 R-te head, and or Head gasket, replacement!
- 1994 v6 Idle issues
- 6 1/2 plow, 92 p/u 22re. can it handle it??
- Radio & cig lighter not working, climate control not lighting up
- 1987 Drivetrain feels like it is loading and unloading going down the road
- What's included with the Steering Link Recall?
- cali thread! what passes smog?
- 89 alternator compatible with 86
- Hydrolocked?
- Super weak 93 4 cyl. Pickup. Please help.
- H.I.D. headlight ideas for a 89 pickup
- 1991 4runner Headlight Question
- timing question
- 94 v6 rubber stop inside the spring - needed?
- truck wont crank/start
- my 4runner
- '89 standard cab pickup as daily driver...
- Throttle Body Swap?
- cheap mods for low end torque and can it handle a plow????
- 86-88 4 runner cargo are pics needed
- Part number needed please
- 22re High Idle and no power. Inconsistent Idle (but not surging)
- 92 Pickup Windshield Wipers
- Carb Problems
- Fuel filter replacement-from top or side?
- keep blowing signal fuse
- Fuel Injector Removal Write-Up (first-time)
- to replace or to not replace: 3vze head gasket
- gears grinding on 94 tacoma
- 1992 3.0l v6 stalls on engagement or at 11-15mph
- timing a 95 pickup
- Need help replacing front lug studs
- Pic Request, 1st Gen 4runner with Lund Visor
- Now this is a unique paint scheme.....My new yota
- 3.0 Heats Up at Low RPM
- 22250-35010, 197100-2350
- Heater Core Plugged...
- gen 2 4runner turn signal issues
- Windshield Tank
- '90 4 runner factory alarm Q
- 94 3vze Terrible Gas Mileage
- Unexpected MPG Drop
- Truck bed swap?
- Brake question
- Newbie w/a Restoration Dream (need advice)
- 3vze #6 EXH valve, Is it burnt? Say maybe not!
- Removed LSPV, now can't build pressure
- Vibration at 60 mph+, goes away when I let off the gas HELP!
- Electrical problems
- 3.0 plenum
- 87 4runner surges during acceleration
- What gear oil to run...
- Chevy 63in spring swap??
- 3vze overheating after valve replacement
- anyone used a seal kit on a power steering pump?
- 95 4runner sr5 automatic tranny prob
- 88 toyota pickup cab interior grounds.
- 3vze tick
- '91 Pickup Intro
- Think I might have a disorder
- 22re motor question
- Installed an aftermarket tach
- Won't start/ no power
- brake swap questions
- Couple 3vze removal questions
- fuel pump issue??
- Car dies when slowing down….
- Does it look like I have coolant in my oil? Please help!
- Violent sounding clutch, bizarre electrical symptoms!
- 95 4Runner speedometer, odometer, trip not working
- aux air valve tech
- Rumbling Vibration in high RPM?
- RFA1 transfer case gasket drawing for ebrake fab
- blown head gasket, no. what now?
- Truck runs hot and ive replaced everything need help
- No CEL light?
- Aisin vs. SACHS clutch kit?
- 4runner running alittle warm
- how to tell if ECU is bad
- Engine surges, pulled codes
- Incident with tree - looking for advice!
- strange washer on engine head?
- Gas smell after start and rough idle
- Timing Chain Cover & Oil pump bolt crisis - any idea's??
- Sky's IFS steering box
- Motor fun
- Irritating fuel filter issue
- Dome Light problem
- V6 Brake swap
- 91 transmission removal/clutch issues
- No heater fan/ '87 P/U
- Good price for used tranny r & r?
- 91 Toyota 22RE will not start
- 88 4runner check engine light and ebrake light!!
- 3vz issues
- Stuck in Monroe nc. Need assistance ASAP.
- 3vze Mass Airflow Sensor Upgrade?
- 88 toyota pickup chassis electrical. grounds
- Thinking of a 2nd gen to 3rd swap
- Starting problems
- How to diagnose a bad air flow meter on a 94 22re.
- Eliminating VSV on PS Pump - 22RE
- rough idle when cold
- How do you tell the differnce between a genuine toyota head and a cheap Taiwanese one
- '87 22re codes
- 87 4Runner 22RE falls FLAT on its FACE at 3500 RPM
- HELP! Driving cross-country, discovered some leaks, need advice
- 2nd gen 4runner wheel bearing replaced but noise continues
- tacoma front clip swap
- Turn Headlights on, I have no Cluster display.
- Engine dies after its Warm
- Attn Wabbit and/or ScottyC or anyone else TG Rear Spring Hangers
- sr5 cluster swap interchange
- 89' 3VZE top end tear down and rebuild
- 22r Exhaust Leak Questions...
- 1990 2Door 4Runner project
- 89 toyota pickup 3.0 fuel pump/relay issues??????
- New truck.. Old problems.. help. **PIC**
- 91 4Runner Transmission issue!
- Low Oil Pressure, High Coolant Temp, Misfiring, Perfect Compression 1995 4Runner 3VZE
- brake shoe size
- brake shoe size
- Temp goes up and down up and down..
- r150 leak
- Heater Water Valve Cable
- ADD IFS swap 1987 pickup.
- W55 Input shaft bearing replacement?
- Guages dont work after bulb replacement
- computer chip?
- power steering, flare cracked?
- plug wires
- On the 22RTE, what do these things do/are they necessary?
- 22RE, no injector pulse
- Oh my god I used UV die and the thing leaks from EVERYWHERE
- Knock Knock, 22re
- Unusual Toyota?
- Replacing 1989 22re Headgasket
- 22RE head gasket & timing chain overhaul
- help getting 4 runner rear hatch open
- Uneven Idle when A/C is on
- 86 22rte bad head???
- Headlamp vertical adjustment part
- 1987 22r wont crank
- Weird ticking sound in my 22re HELP!!!
- 1993 Pickup Gas Starving/puttering issues
- 93 Pickup auto tranny horrible vibration in 4x4
- Odd whirring... tranny failure
- Fuel smell after head gasket r&r. Wet #1 injector
- 1st Gen 4runner Front bumper strength for flat towing
- Uncontrolled reving
- 86' 4runner 22re, cold start injector and time switch test out fine?
- Surging throttle and black smoke
- Heat issues! Help!
- '87 4Runner -- FJ tire share and max tire size?
- oil leak
- Well MrArmyAnt is back in a Runner like he should be...
- 88 4 runner transmission noise, possible causes?
- Weird 3.0 problems?
- tranny trouble
- 88 3.0 4x4 shocks. and suspension advice needed
- Help! Need a speedo cable
- Replace hard fuel line with rubber?
- Best Bumper/Rock Slider Coatings
- motor swap from 95 4 runner to 87 4 runner
- 63in chevy mounts
- 90 4runner V6 unique auto tranny problems
- need AISIN manual hub faceplate or ideas!
- 91 22re wont idle when warm
- Clutch or break issue???
- 22re temp and knock senser
- Installed my clock today.
- Wheel Bearings
- "Who needs a thermostat anyway"
- drivin' 4x4
- 87 pickup a/c
- oil pressure test
- O2 Sensor bad after 200 miles??
