3vze tick
Old Nov 12, 2011 | 04:52 PM
turkey's Avatar
3vze tick
my motor only has around 2000 miles on my motor, and at idle with the hood up i can hear a tick on both sides of the motor.I cant hear it when driving so im guessing it doesnt get worse with load and rpms. could this just be my injectors? when i rebuilt my motor the injectors looked fine so i went bad with them, not sure if them being old would cause them to tick or not. is there any reason i would have to adjust my valves so soon after rebuild??
Old Nov 12, 2011 | 10:16 PM
4wd4fun's Avatar
injector will make a tick like noise
i was worried before because my 22re does that. injectors all opened and closed each rev of the crank so i thought first was valves then exhaust leak but since those happen every two revs of the crank felt confident it was injectors.
Old Nov 13, 2011 | 07:27 AM
turkey's Avatar
how loud would my injectors be? with the hood popped i can easily hear it but with it shut cant hear it so not to loud i dont guess. and will the injectors tick be more back to back than a valve tick?
Old Nov 13, 2011 | 03:26 PM
bmcghie's Avatar
My injectors got louder when they came back from being cleaned. It is a pretty serious tick! I'd liken it to tapping a ball point pen on your finger really quickly, and a fair bit louder.
You might also be hearing your speedo cable, or (more likely) the fuel pressure damper. The damper gets a bit louder before it fails... but mine has been fluttering for the last 3 years with no adverse affects. The fuel damper sounds like it's coming from the firewall itself
Your injectors might get louder under heavy load with no increase in rpm. That might help you differentiate between them and valves.
Old Nov 14, 2011 | 03:51 AM
TNRabbit's Avatar
Injectors & the fuel pressure regulator tick like a SOB. It's normal.
MadMax48
Mar 3, 2020 10:33 AM
Davebarbier
Nov 3, 2015 03:28 PM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
