63in chevy mounts
Old Nov 4, 2011 | 08:31 AM
runs-on-4's Avatar
63in chevy mounts
anyone suggest getting these
http://www.lowrangeoffroad.com/yotam...-swap-kit.html
does anyone have a better link?
Old Nov 4, 2011 | 09:05 AM
scuba's Avatar
That's a decent kit. Decent price for 1 stop shopping. I'd buy it. Check out Ruff Stuff. They might be a little cheaper all together.
Old Nov 4, 2011 | 09:18 AM
runs-on-4's Avatar
have you ever bought from them? do they ship fast?
Old Nov 4, 2011 | 11:24 AM
scuba's Avatar
Never bought from either company. I've heard tons of great feedback about ruff stuff, which is why I recommended them. Call the company and ask when they'll ship..
Old Nov 4, 2011 | 11:38 AM
xxxtreme22r's Avatar
ruff stuff is also a vender on here. https://www.yotatech.com/forums/f226...ap-kit-239298/
Old Nov 4, 2011 | 02:53 PM
Stuwy123's Avatar
That's a nice looking kit.
I went the homemade route and made my own mounts.
I left the bottoms of the front mounts on for extra support and skid protection (I guess).
I didn't make a rear mount, I just made some longer shackles and mounted them to the stock rear mounts.
I also installed new bushings into my springs, no squeaking what so ever. Makes my buddy with an 06 Tacoma really jealous. Haha.
Bushings were $40, springs were $40 (i think), steel was free.
You'll need to do something with the front because you'll be getting a couple inches of lift. I had to crank the torsion bars all the way to bring it back to stock rake.
I don't know how high it was stock but the top pic is my truck before and the bottom is after. You can see how much lift I got from the fender well gap.
Old Nov 4, 2011 | 05:29 PM
runs-on-4's Avatar
i have a 4inch lift up front? was yours stock height?
Old Nov 5, 2011 | 02:07 AM
95 4Runnin's Avatar
that is a good kit i just got a set of 63in chevy leaf spring im probably going to order those one
Old Nov 6, 2011 | 10:14 AM
Stuwy123's Avatar
My truck wasn't stock height at the time of those pics.
3" body lift (that doesn't change the suspension though)
The first pic was basically flat suspension.
The rear springs only had maybe an inch or two before the bump stops (which it hit them alot).
And the front was basically flat as well.
The front suspension arms were flat and parallel to the ground where as they should be more angled.
The second pic is the same front suspension with 63" chevy springs in the back. Lots of up travel.
Old Nov 6, 2011 | 10:18 AM
Stuwy123's Avatar
I would recommend just installing the rear springs first and then tinkering with the front to get it sitting properly.
Some say that a 4" suspension lift will match a 63 chevy spring swap in the rear. That could be true, all depends on the length on your shackles, if you moved your rear shackle mounts or kept them stock, and of course, how many leafs you have and how worn out they are.
(Mine are 3+1 (3 main leaves plus the overload).
Do the rear spring swap, then worry about the front.
Stuwy123's Avatar
Pirate is your friend.
http://pirate4x4.com/forum/showthread.php?t=20665
Old Aug 10, 2012 | 09:54 PM
travyota39's Avatar
runs on 4 what did you end up doing?
Old Aug 12, 2012 | 07:26 PM
runs-on-4's Avatar
I went with sky's off road kit but lost one of the spring hangers so I bought trail gear hangers
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
scott90
Oct 4, 2015 09:21 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
