Eliminating VSV on PS Pump - 22RE
Old Nov 8, 2011 | 06:44 PM
jstluise's Avatar
'87 22RE
My PS pump went out so I will be installing a replacement. I was thinking about getting rid of the VSV for a couple reasons: 1) I'm not sure it is really working right now, since my idle doesn't increase when I turn (at a stop) and 2) it is one less thing to cause problems in the future.
Thoughts?
Old Nov 8, 2011 | 06:57 PM
TNRabbit's Avatar
Remove it & block the vacuum lines. I haven't missed mine in the past 4 years....
Old Nov 9, 2011 | 07:57 AM
scope103's Avatar
You'll need to set the idle up without it (or risk killing the engine when you're parallel parking). But as you've seen, lots of people get by with one or both of those conditions.
When I replaced my PS pump the rebuilt came with a new idle-up (VSV) valve, so it was a no-brainer for me to reinstall it and enjoy the convenience designed in by Toyota.
Old Nov 9, 2011 | 08:14 AM
qdude79's Avatar
I did the same when replacing mine and have yet to see/feel any effect from it. I must be doing something wrong.
Old Nov 9, 2011 | 08:18 AM
4Crawler's Avatar
Been w/o that for 10 years or so now since putting on a TC pump on my '85. Cap the two vacuum ports
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/11.html
and call it good. I sometimes find I need a bit more power steering boost at idle and if so, I just blip the throttle with my foot.
Old Nov 9, 2011 | 10:07 AM
jstluise's Avatar
Sounds like a plan. I guess if the rebuild comes with a new VSV I'll use it (I don't think it does), otherwise I'll just do away with it.
With normal operation of the VSV, should the idle remain constant or increase a little when you turn? As it is right now (well, before the pump went out), my idle stays constant when I turn.
Old Nov 9, 2011 | 10:11 AM
4Crawler's Avatar
Should be just like the A/C idle up (if you have A/C). Supposed to bump up the idle speed to the point you have the fast idle adjustment screw set to when the p/s pump goes into high pressure mode, like if you have the tires against a rock (or curb) and try to steer.
XtraCab
Apr 12, 2020 05:25 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Poppie51
Jul 23, 2015 05:03 PM
Fundy Rider
Jul 16, 2015 01:35 AM
