- 1987 4Runner Head Gasket
- 94 Runner Blower motor removal
- Insurance costs are outrageous!
- Smashed Up My runner
- relocating stereo
- trying to make it up hills.
- Im an idiot.
- Bad things happen in three. 22R headgasket.
- Shifter
- 4Runner won't run.
- Power Steering problems
- Well I found my new (to me) 4runner.
- Need help getting Automatic Locking Hubs Off
- San Diego Engine rebuilders
- Sticky Clutch and Clutch Fluid
- brakes sticking
- Throw down time
- 22re went KABOOM!
- a/t temp light flickers
- Dual Shocks
- Starting and a clunk and the engine dies
- 3VZE Valve clearance check upon rebuild.
- BJ spacer, wheel/tire set up
- OEM steel spare rim width
- O2 sensor
- idler arm rebuild somehow gone wrong. please share words of advice. =\
- if you want a sa for 100 bucks?
- brake problems...
- 3.0 remove/Install questions
- help! jumped the radio power now theres no cel
- how should i lift?
- Good Toyota Shop?
- Noises
- Stuck Calliper Replacement question.
- Sr5, dlx, wth??
- 86 fuel gauge
- 22re distributor wires
- How to break my transmission?
- squeaking noise
- lil lift
- Aux. Backup light problems
- Soft clutch after replacing clutch bracket and other issues
- Auto or manual?
- 2nd gen 4runners
- ok final straw with torshionbars
- Full 86 - 95 toyota pickup repair manual (little extra too)
- knock knock, who's there...?
- how to add a tachometer
- engine swap with or without transmission ???'
- IFS to SAS
- motor wont run
- Tread Wrights and Miles on them.
- power steering on 93 4runner
- accessories Questions
- help with 4x4 engagement please
- A/T Temp light came on while towing
- removing rear bumper and dim headlights
- Rebuilt 3.0 wont start
- Would it be against the law, or copyright infringement if I...
- Having Trouble
- 93-95 4runner question
- little help needed if you have a 4x4 truck 90-94
- power to front windows
- Can you adjust the clutch cable
- what parts from 4wd to prerun 2wd
- irratic vss signal after 5.3/4l60e swap
- Oil ridden Spark Plug help - Pcv Valve?
- Suggestions Please
- Injector advice!
- 86 22ret engine will not stay running help
- Rusted On Cat Bolts
- driveway alignment write-up
- oil pressure guage. 1988 3.0
- FUSE diagram, cover, order, map, (need specs)
- Super Loud Sound -- Possibly Power Steering?
- rear heat?
- Im haveing starting problems when hot...
- Thule roof/safari basket
- 93 3.0 engine problems
- V6 rattles when accelerates or lets off gas?
- 125 dollar carb now? 600 dollar exhaust later
- When replacing a driveshaft
- Overdrive light flashing on and off.
- 1987 Yota will not start, changed starter...
- Blew Up the Front Dif!!!
- '88 4Runner blower
- Hangover run!
- high volume oil pump?
- Missing cylinder
- New 4runner owner :)
- Ugh, I still can't win. Idle/Throttle issues.
- How to remove the distributor?
- One-eyed monster: sealed beam question
- 94 4runner 3.0 problems
- Extended brake line woos...
- newby spring question
- Belt tensioner
- GM one wire
- 86 22rtec turbo wont stay running Help
- Body panel sealant?
- low mile original find in oregon
- 22RE Warm Idle Changes From Trip To Trip... Why?
- No Signal To Fuel Injectors 87 4Runner Turbo
- Transmission went bye bye...I think. Help.
- Flywheel rusty after cleaned
- engine swap
- 2 wheel drive question/help/advice?
- CLUTCH BLEED, Still soft, how much fluid fills the lines?
- bad headgasket? bored over?
- swap information
- 86 RE engine, few questions.
- MC Front bumper on a 3rd Gen PU
- Runner 3.0 v6 exhaust
- WOOHOO finally!
- Side Mirror Hella 500's
- center console
- 'splain me differentials, 2nd gen 4runner
- what guage sheet metal?
- How do you get the starter motor back into it's housing?
- Head stuck to block
- Trouble with Timing.
- 87 22RE Won't Rev Past 2000
- Desel engines
- light problems
- Just can't decide...
- My 4Runner is bucking/ lunging
- time for a new driveshaft?
- large gas leak in 94 pickup
- Timing problem.
- After installing timing belt.
- Leaky stinky moldy cab
- 4Runner rises up out of hibernation
- dash lights go bye bye
- Engine Compartment Wiring harness ground lug?
- Ford 4.0 into '86 Pickup?
- anyone have experience with kwan tanabe motors in LA?
- Tie Rod / Pitman Arm / Bushings Question
- Pipe Help and Terminology
- Looking for a spare tire holder
- speedometer cable
- h4 ebay conversion repair
- 3vze- think the timing belt went
- Motors running
- Is anyone running this combo??
- offroad clean up?
- Oil Pan Removal
- saggy rear on my runner
- Heya folks!
- Inconsistent oil pressure
- Rear axle question
- 4Runner 2nd generation Price guide
- 93 'peekup truck front gear change knowledge needed
- Truck starts but quits running in 2 seconds.
- hard break pedal
- Differential problem?/locker install?
- 93 4Runner brake work
- 93 4Runner 22re cold starting issues
- Mud flaps and marlin crawler bumper
- 87 runner, poor idle
- Also a $3.99 Gille Modification
- Is there a HURST style shifter knob for Yotas?
- HELP! brake lights dont work!
- More IFS flex
- 86 22RE - Sudden drop in gas mileage & engine miss
- Gas Tank Woes
- Toyota Thermostat
- Late christmas for my runner
- I like my horn just fine thank you
- Coolant Leak, backside 92' 3.0EFI
- Update on the diff and driveshaft rebuild...
- No idle
- Noise from heater core
- Any 22r guys have experience with LC carb adapter and K&N air cleaner?
- 93 3vze question
- Clutch release bearing retaining clip picture?
- Crossmemer drop
- Looking for a bed
- Thrust Washer / Shim Kit?
- need help plz!
- code 13 and 43
- a few questions 'bout lockers
- New play toy!!
- differential extension ???
- noob question
- Power Steering leaking..I think
- 22re Headgasket question
- Look what i got today!
- white smoke of death...
- 22re temperature/thermostat questions
- 22re and rpms
- Vibration problem solved..thanks!
- 22re turbo -EFI limts
- Timing belt?
- Clanking Noise when in 4wd
- Late night boredom mod
- Trouble knocking out studs out of upper balljoint
- What else do I need?
- The Boys back home
- Another 4Runner for my dad!
- 20r and 22r clutch
- 1990 4x4 Brake Problem
- Nor Cal here
- ugh, i need quick help
- P/S/ pump
- gear interchange questions
- Homemade PB Blaster??
- P/S Belt Routing?
- Fan Bracket Won"t Fit on 3.0
- Smaller Pipe From Exaust?
- running hot & wierd/new everthing(almost)/please help
- camper top questions
- 4cyl third into v6 housing?
- Look at what i found
- Good deal??
- What would you pay for. . .
- 1990 4runner wont start! engine has fuel and spark!!
- 3.0 transmission applications...will it work?
- 4runner passenger seat swap question
- 4runner lockbox and plastic rear panel replacements
- Best Heater Hose out there?
- 2" downey leafs with 5" shackles?
- Hit and Run! SO mad right now!
- Where to get a GOOD new CatConverter???
- Drop-in Bedliner
- ugh.. Rear Antilock light on, and stays on
- Ignition cylinder Problems
- Stock ECU- what HP # is good for?
- Brake Fluid Cap Any one???
- Has anyone tried a 4.0 swap
- New 1990 toyota 4x4 with pics.
- How bad of a job-replacing rear pinion bearing?
- Strange electrical Problem
- 3.0 engine reliability
- 3.0 block heater location question.
- scrap metal anyone?
- Nerf Bar Install
- 3.0 smell
- 93 4x4 Trans Issues
- Bed lining the roof
- 87' 4runner motor swap
- Home alignment- caster question
- brand new 3VZE
- What is my rear end gear ratio?
- tacoma bumper fit on a 93 pickup
- Transmission Problems
- Rear Third
- Deep cycle battery?
- Rim size recommed
- timing chain cover question
- top dead center
