Injector advice!
Old Jan 5, 2009 | 06:27 AM
asaj's Avatar
Injector advice!
Say I have a bad injector and I have taken it out and cleaned it. Does anyone know of a good test to see if it has been done right with out putting everything back together?
Old Jan 5, 2009 | 06:41 AM
mt_goat's Avatar
The FSM has a test proceedure, but it may be more involved than you'll like.
http://personal.utulsa.edu/~nathan-b...31injector.pdf
Old Jan 5, 2009 | 10:14 AM
DupermanDave's Avatar
Try hooking a 9v battery to it. It will at least tell you if it's opening and squirting gas out of it.
You should be able to see it "spit" some fluid out of it if there's still some left inside.
Old Jan 5, 2009 | 11:57 AM
asaj's Avatar
I would like to know the test procedure and I will try the 9v battery trick.
Old Jan 5, 2009 | 02:01 PM
mt_goat's Avatar
Originally Posted by asaj
I would like to know the test procedure....
The one for the 22re is in the link I posted above, about half way down the page. Here's the one for the 3VZE: http://personal.utulsa.edu/~nathan-b...90injector.pdf Kind of strange they both have the same flow specs, maybe that's a misprint.
Old Jan 6, 2009 | 02:17 AM
TNRabbit's Avatar
Be careful hooking a battery; it should only be connected for fractions of a second at a time as you can burn up the actuator. It's firing several HUNDRED times a minute under load....
Old Jan 6, 2009 | 04:53 AM
asaj's Avatar
Thanks for that link that is going to come in handy! Im Going to do this first thing saturday moring and I will let you guys know!
jb451
7
Oct 7, 2022 06:58 AM
djohnson13
Sep 4, 2015 12:35 PM
ocfatman
Sep 3, 2015 05:49 AM
digdug40
Aug 28, 2015 02:24 PM
matrad
Aug 8, 2015 03:00 PM
