ok final straw with torshionbars
Old Jan 5, 2009 | 09:14 PM
90inworks's Avatar
i cant get them to budge. now if i cut them will the bolts will they like fling? or can i do it? i have new bolts. but the front is sagy it needs to go up. or should i unbolt the wholetorshion bar assembly and then cut the bolts. i dont know how to go about this one lol
Old Jan 5, 2009 | 09:24 PM
Matt16's Avatar
Are you relieving the pressure by lifting the truck off the ground? That's a must. Another must is a breaker bar and penetrating oil if the bars haven't ever been adjusted. I wouldn't cut them out from the head of the bolt as I think you might have to cut a hole in the body to get it out.
Old Jan 6, 2009 | 05:54 AM
90inworks's Avatar
i am taking the pressure off. i can get them to turn but the nut on top is seized up.
Old Jan 6, 2009 | 06:14 AM
Hypoid's Avatar
It's relatively common for that to happen.
Soaking it in Kroil or something of that tier (rather than PB Blaster or Liquid Wrench) *may* help. Wedge a wrench on the nut to hold it still and use a big breaker bar. Don't be surprised if you have to break the bolt because the nut doesn't come off.
https://www.yotatech.com/forums/f116...-bolts-160355/
Replacement bolt/nuts are relatively cheap.
Davebarbier
Nov 3, 2015 03:28 PM
scott90
Oct 4, 2015 09:21 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
tylermx71
Sep 29, 2015 08:49 PM
