cold start injector problem
Old Sep 1, 2015 | 08:00 AM
ocfatman's Avatar
So.....Changed injectors, fuel pressure regulator, and fuel line to cold start injector.
Now my cold start isn't activating.
Any ideas?
Old Sep 1, 2015 | 09:43 AM
scope103's Avatar
Originally Posted by ocfatman
... Now my cold start isn't activating. ...
How do you know?
Describe it to us. Especially what you are doing when you think it "should" activate, and what it is that tells you it isn't.
The CSI is only on during cranking. The CSI Timer will cut off the CSI a) if the engine is warm and b) after some (very short) length of cranking.
Of course, "hard starting" alone can be caused by so many things that it isn't diagnostic of anything, so I'm pretty sure you've got more.
Old Sep 1, 2015 | 09:56 AM
ocfatman's Avatar
Originally Posted by scope103
How do you know?
1990 4runner 3.0
Just wanted to point that out.
I pulled the cold start off and cranked motor.....nothing. No spray, no mist, not even a trickle.
Detached the fuel line going to it and it was dry. Creepy cause I know other end is connected to fuel rail.
Runner will start after over-cranking and once on it runs decent. Just the starting is bothering me.
Old Sep 1, 2015 | 10:27 AM
scope103's Avatar
The fuel line to the CSI connects directly to the fuel rail. If the 4runner will run, you have pressure in the rail. If there is no flow at all (with the line disconnected from the CSI), it sure sounds like something is plugged!
(You might be tempted to "blow into" the CSI end of the line, to blow out whatever is stuck in the line. I wouldn't do that; whatever is blocking the line will just end up in the injectors, and that can't be good.)
You could try one more step; disconnect the fuel line from the CSI, put it into a container (with a rag over it; at full flow it will splash), and tap the fuel pump with the FP connector. If fuel flows then, you may just have a CSI not opening, and the line is "dry" because the slug of air in there just never moved. If you get that far, I would then test the CSI http://personal.utulsa.edu/~nathan-b...88coldstar.pdf and the CSI timer http://personal.utulsa.edu/~nathan-b...ne/97colds.pdf
Old Sep 1, 2015 | 08:25 PM
ocfatman's Avatar
Thanx!
I'll try that tomorrow and post results!
Old Sep 1, 2015 | 10:40 PM
Marsheen's Avatar
Do you have the link to the entire Factory Service Manual in pdf file?
Old Sep 2, 2015 | 03:49 AM
AKHeathen's Avatar
if it is running and there is no fuel at the csi, you certainly have an obstruction in there. as stated, don't blow it to the injector rails, just pull it first and clean the line out.
Old Sep 2, 2015 | 04:23 AM
ocfatman's Avatar
I don't. That'd be a nice link to have tho!
Old Sep 2, 2015 | 06:28 AM
ocfatman's Avatar
Thanx!
After further inspecting the situation....
I found the line is pinched betwn plenum and valve cover.
Crap!
I'm afraid that if I attempt to free it, it'll be broken or it'll break in the process. I'll have to start looking for one before I get myself into another jam.
Old Sep 2, 2015 | 07:50 AM
scope103's Avatar
23901-65010
http://www.toyotapartsoverstock.com/...rimLevel=18292 About $80
Don't forget that you need to replace all four of the crush washers when you replace that line. I've never found them but at a dealer, but they are cheaper than dirt. Cheaper yet if you're ordering the line; you can include the crush washers with no add'l shipping.
Old Sep 2, 2015 | 09:48 PM
AKHeathen's Avatar
might be able to fix it with a brake line mender.
Old Sep 3, 2015 | 05:49 AM
Terrys87's Avatar
A pinched line is going to be a problem. On a 22re, I have never had a CSI to fail but the Timing Switch that contols the Injector is the one that fails and causes issues.
jennygirl
Nov 17, 2015 11:24 AM
viesail
Jul 6, 2015 10:16 AM
jmc88runner
Jun 18, 2015 03:39 PM
scott
Jul 15, 2002 07:56 AM
