22RE Warm Idle Changes From Trip To Trip... Why?
Old Jan 3, 2009 | 09:16 PM
qdude79's Avatar
Fires fine, cold idle works every time. No change with brake pedal pressure, no known vacuum leaks. Intake plenum clean, EGR clean.
Now, once warm, idle is one of two things: normal (~800rpms and steady) or low (~550rpms and steady). Low idle is very rough and sputtering, but doesn't fluctuate. Still picks up fine from the stop sign. Sounds like crap and sometimes (rarely) dies. Park for a trip to the store or something, come out, may idle fine, may be rough. No rhyme or reason.
Ideas?
Old Jan 3, 2009 | 09:20 PM
4banginRunner's Avatar
check TPS? might be out of adjustment, or shot
plugs?
clogged cat?
abe is sure to chime in on this..
Old Jan 3, 2009 | 09:22 PM
qdude79's Avatar
TPS is on the list! Cat, plugs, etc. have about 1500 miles on 'em, so possible, but not likely. Good call, though.
Old Jan 3, 2009 | 09:26 PM
22RE's have alot that can contribute to a strange idle, its best to go with the cheap basics first
Old Jan 3, 2009 | 10:03 PM
toyota4x4907's Avatar
My '93 does this very rarely, maybe every 1K-2K miles and hasn't done this since the temperature dropped below 0*F in November. Check the coolant temperature sensor, make sure the coolant is at the right ratio, and no air is present in the cooling system. Check what 4bangingRunner said as well
Old Jan 3, 2009 | 10:49 PM
91Toyota's Avatar
My idle changes all the time. If i drive 10 miles on the freeway it will idle at 750. If I go for 100 miles it will stick at 1000 or so. Seems like giving it a rev or two will lower the idle. I think the dash pot is a piece of crap. And isn't functioning properly.
Sleaker
Aug 26, 2020 06:03 AM
ty1er
Jul 19, 2015 06:42 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
skoti89
Jul 6, 2015 07:45 PM
