GM one wire
Old Jan 4, 2009 | 07:02 AM
ethomas3307@bellsout's Avatar
Question GM one wire
I am thinking of putting a one wire on my 87 truck need more power for stuff what do you do about the charge and brake light and the wires off the old alt
Old Jan 4, 2009 | 08:31 AM
RunnerUp's Avatar
what did you just say?
Old Jan 4, 2009 | 08:39 AM
parkkicks's Avatar
x2
Old Jan 4, 2009 | 08:44 AM
My99's Avatar
I saw GM. My vote is no.
Old Jan 4, 2009 | 08:50 AM
the_ocho's Avatar
i think he wants to put a gm alt in his truck and doesnt kno how to hook up the wires to it
Old Jan 4, 2009 | 09:24 AM
Ok tell me a cheaper way to get 100amp alt then
Old Jan 4, 2009 | 09:26 AM
i know how to hook the gm up you know any on could do that i hope but what am i going to do wiht the light that comes on it will think the alt is not working
Old Jan 4, 2009 | 09:39 AM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I think there is a thread on here that shows how to convert the connectors to run an AC Delco alternator. One thing though, it is hard to read your posts with no puncuation.
Old Jan 4, 2009 | 09:41 AM
hahahaha
Old Jan 4, 2009 | 10:08 AM
I found this link on ebay. But i do not know if it will do 120 amps! And i know the stock wire will not handle 120 amps. So i would have to up grade it!! I am waiting on email back from guy.
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
Old Jan 4, 2009 | 10:16 AM
iamsuperbleeder's Avatar
geez, fer that price, if you get it, let us know how it works out!
Old Jan 4, 2009 | 10:24 AM
muddpigg's Avatar
X2 try it and post results.
Old Jan 4, 2009 | 10:28 AM
the_ocho's Avatar
after reading this i looked and they have them for 3.slows too. so let us know how it works then i may just buy one
Old Jan 4, 2009 | 10:35 AM
INFINITY's Avatar
like this?
http://www.toyotaoffroad.com/Article.../Chevy_Alt.htm
http://www.rocketcityrockcrawlers.co...%20Project.pdf
4crawler's site
Old Jan 4, 2009 | 11:00 AM
myyota's Avatar
You can get a 100 amp alt from a 91 MR2 with power steering, you will need to put the pulley from your old alt on the new one, and it should be either a bolt in or very close to it.
Old Jan 4, 2009 | 12:22 PM
Matt16's Avatar
The 3VZE and 22RE have different alternators. The MR2 alt only works on the 3VZE. Not sure about the GM.
"GM" alternators aren't built by GM per se, I think they're build by AC Delco. Toyota alternators are built by Denso.
ET3307: What engine do you have? Let us know how it goes.
Old Jan 4, 2009 | 02:39 PM
muddpigg's Avatar
Saw a posting on the MR2 awhile back seems that it would require as much modifying as a GM to fit. I like 4crawlers set up bet. All other either require cutting the engine block bracket or the Alt housing. With the Adaptor the 4crawler made you wouldn;t need to do either, seems he got the idea from an onboard welder company. Think all the different options require the extending the Adj. bracket. There was a guy on here that was selling a made kit new engine and adj bracket for under $100. Been awhile since I've seen it though, you supply Alt.
Old Jan 4, 2009 | 02:48 PM
Windsor's Avatar
Why not just do the 100A rebuild conversion that has been posted in other threads?
Old Jan 4, 2009 | 03:00 PM
I have looked for that but can not find it......
Old Jan 4, 2009 | 04:05 PM
Windsor's Avatar
https://www.yotatech.com/forums/f116...pgrade-162594/
