GM one wire
Old Jan 4, 2009 | 04:06 PM
Windsor's Avatar
oh, 90amp rebuild upgrade. my bad.
http://www.4x4wire.com/toyota/tech/alternator/
Old Jan 4, 2009 | 05:07 PM
myyota's Avatar
Originally Posted by Matt16
The 3VZE and 22RE have different alternators. The MR2 alt only works on the 3VZE. Not sure about the GM.
"GM" alternators aren't built by GM per se, I think they're build by AC Delco. Toyota alternators are built by Denso.
ET3307: What engine do you have? Let us know how it goes.
As far as i can see there is nothing different between the MR2 alt and 22RE alt, the electrical conections are the same, the only difference i can see is the pulley, and that can be changed, other than that its just a matter of making it fit in the stock mounting brackets. if there is something im missing then let me know.
Old Jan 4, 2009 | 05:15 PM
the_ocho's Avatar
i think its just the mouting brackets that are diffrent. the mr2 alt will bolt up to a 3vze all you have to do is add a inch to the adjuster bracket
Old Jan 4, 2009 | 05:16 PM
abecedarian's Avatar
One other thing about the '1 wire' GM alt is that you'll lose the light on the dash telling you it's not working. The toyota alternator's regulator takes voltage passed through the indicator light on the dash and grounds it when the voltage output drops below a certain threshold thus turning the light(s) on in the dash.
Old Jan 4, 2009 | 05:21 PM
  #25
myyota's Avatar
My 86 4Runner has a 22RE and i should be able to to make the MR2 alt work on my truck as well, Its just a matter of moding the mounting brackets a little to make it work.
Old Jan 4, 2009 | 05:24 PM
  #26
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
You can have your stock alt re-wound to a higher amperage, and it would prolly be less than trying to mad a GM or MR2 version.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
