How to remove the distributor?
Old Jan 4, 2009 | 10:50 AM
xzyragon's Avatar
Well, my distributor is bent and cracked, and I got another one, I just can't figure out how to remove the old one... (22re btw)
Any help would be appreciated
car crashes suck
Old Jan 4, 2009 | 10:52 AM
DeathCougar's Avatar
Your dizzy is BENT and CRACKED? What the hell did you hit it with?!
What motor are you working on?
Both the 22RE and the 3VZE are removed in the same manner. Unplug all the plug wires, and the wiring connector going to the distributor, then loosen and remove the 12MM bolt that secures it to the block, and wiggle it out. Very easy to do.
Old Jan 4, 2009 | 10:53 AM
algranger's Avatar
pull the 12mm bolt that you use to adjust the timing and it should slide right out. you will want to set the motor to TDC so you can get the new distributor in the right position
Old Jan 4, 2009 | 10:54 AM
algranger's Avatar
yeah, that.
Old Jan 4, 2009 | 10:57 AM
xzyragon's Avatar
well...
i was in a car crash, almost totaled the car, but Im puttin the thing back together cuz its a dam fine car
Old Jan 4, 2009 | 11:01 AM
algranger's Avatar
oh that makes sense
Old Jan 4, 2009 | 12:03 PM
iamsuperbleeder's Avatar
or just remember, take a picture, or mark which way the rotor was pointing, and install the new one clocked to the same position
just don't turn the motor over while the distributer's out, or you will definately have to find TDC and go from there...
Blamalam
Mar 12, 2022 07:34 AM
AppalachianOffRoader
Aug 11, 2015 01:15 PM
nonstop
7
Aug 11, 2015 09:26 AM
Flossy
Aug 5, 2015 05:14 PM
