89 P/U starts but wont run.
Old Aug 11, 2015 | 10:16 AM
AppalachianOffRoader's Avatar
I had to pull a few things to do some maintenance. I got everything back together (or so I thought), and now my truck starts and sounds great for about 3 seconds, then it dies with an accompanying smell of gasoline.
I pulled the distributor during the maintenance, the first time I put it back in it was 180 out so it wouldn't even start. Fixed it, so now it starts but won't run. I'm assuming my issue is probably a vacuum hose routed incorrectly, or something to do with my distributor. I didn't remove anything else that would cause these problems like a fuel line or pump etc..., and my truck was running good before.
Any other ideas? It's hot out and I'm taking a break...
Old Aug 11, 2015 | 10:19 AM
RJR's Avatar
RJR
Check out this thread. Sounds like the same problem.
https://www.yotatech.com/forums/f116...issues-290364/
Did you reconnect the air intake from the air cleaner and air flow meter (VAFM) to the throttle body? Leaving that open will cause the symptoms you're seeing. Also leaving off the electrical connection to the airflow meter.
Old Aug 11, 2015 | 10:24 AM
Well I feel stupid now! I forgot to plug the VAFM connector back up.
Thanks!
Old Aug 11, 2015 | 11:07 AM
RJR's Avatar
RJR
That'll do it. You're not the first one. Glad it's running again.
Old Aug 11, 2015 | 01:15 PM
Terrys87's Avatar
I mde that mistake one time as well. It is one that you wont forget now. Glad you let us know that you got it fixed.
Doug4320
Mar 24, 2018 10:11 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
