how to add a tachometer
Old Jan 5, 2009 | 08:24 PM
xzyragon's Avatar
As title says, how exactly would you add a tach to the dash?
Since im pretty sure it's possible, is it easy, cuz I really don't wanna have to go tearin my engine apart to install it...
Second question... any1 know where to get a cheap FULL distributor? Not lookin for after market, just OEM and the full thing, cuz my entire one is busted and cracked T_T
Old Jan 5, 2009 | 08:25 PM
the_ocho's Avatar
i think a tach is just hooking a wire to the coil. im not sure what else
Old Jan 5, 2009 | 08:32 PM
xzyragon's Avatar
ya, well, since its a manual tranny, a tach would be a rather good thing to have...
Old Jan 5, 2009 | 08:33 PM
the_ocho's Avatar
naw just shift when it stops pulling hard. lol
but i shift by sound and feel. i hardly ever use my tach.
Old Jan 5, 2009 | 08:34 PM
874runnersr5's Avatar
^ hahahaha
yeah, you dont have to "tear" into your engine to install a tach. i think the yota's run off the dist for rpm tach. And your best bet to find a dist is the junk yard
Old Jan 5, 2009 | 08:41 PM
xzyragon's Avatar
thats what I did, I just kinda wanted to know RPM to optimize gas mileage n' stuff. Besides, the pedal starts vibrating when I get to too high of RPMs
toyota4x4907's Avatar
Tachs are cool though, the_ocho
But like he said, just shift when it quits pulling as hard.
Also, you can shift by speed. The recommended shifting speeds for the 22re (im pretty sure the 3vze is the same) is 1st to 2nd at 15mph, 2nd to 3rd at 25mph, 3rd to 4th at 40mph and 4th to 5th at 45mph. These are the "recommended" speeds to keep optimal fuel economy.
Old Jan 5, 2009 | 08:43 PM
xzyragon's Avatar
exactly what I've found, cept 4th to 5th depending on roads is normally at around 50
Old Jan 5, 2009 | 08:44 PM
scuba's Avatar
When I shift like that ^ with 31's and 4.10's I feel like im a grandma...
Old Jan 5, 2009 | 08:49 PM
the_ocho's Avatar
do you want one of those big ricer tachs that go on your dash?
Hm. I think I remember the owners manual saying 4th to 5th at 45, I could be wrong. Of course I don't follow that, I don't even use 5th anymore, and rarely 4th
As do I man, as do I.....
I also love the sound of these 22res revving
Old Jan 5, 2009 | 08:50 PM
the_ocho's Avatar
Hm. I think I remember the owners manual saying 4th to 5th at 45. Of course I don't follow that, I don't even use 5th anymore, and rarely 4th
haha with my isr and exhaust my 3.0 sounds mean. i love it
Old Jan 5, 2009 | 08:54 PM
4Crawler's Avatar
Just grab a cluster out of a similar (generation and engine) vehicle to yours that has a tach in the cluster (typically an SR5 model). It'll have a tach in the cluster right next to the speedometer and also will have an oil pressure gauge (you'll need to grab the oil pressure sender below the oil filter and swap that into your truck as well).
Old Jan 5, 2009 | 08:55 PM
abecedarian's Avatar
adding an aftermarket tach is fairly simple: connect the signal wire to the tach to the - terminal on the coil.
you'll have more issues with getting the backlight on the tach to dim with the dash lights than you will getting it to display RPM's.
Old Jan 5, 2009 | 08:58 PM
Originally Posted by 4Crawler
Just grab a cluster out of a similar (generation and engine) vehicle to yours that is an SR5 model. It'll have a tach in the cluster right next to the speedometer and also will have an oil pressure gauge (you'll need to grab the oil pressure sender below the oil filter and swap that into your truck as well).
SR5s weren't the only trim with tachs and oil pressure gauge, right? My '93 DLX has those, and its not SR5 swapped as far as I know. I mean, they were probably options on DLX, right? and standard on SR5?
Old Jan 5, 2009 | 09:10 PM
AZ89LONGBED's Avatar
http://www.autoanything.com/GenericP...ProductID=4128
This one is sweet, 2 & 1/16th diameter, 5k rpm...
Old Jan 5, 2009 | 09:17 PM
xzyragon's Avatar
nice, retro too
Old Jan 5, 2009 | 09:20 PM
darksoldier313's Avatar
what yr and engine r u looking for a distributor i have 2 for an 81 22r and yes it just runs of the distributor the key is where to mount it if u have a spot for it in the dash awesome if not u will have to mount it
Old Jan 6, 2009 | 12:01 AM
rusche's Avatar
Seconded. Never got mine to dim. Lights up with the lights though, just not on the dimmer.
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
Tcsdef
Sep 7, 2015 11:17 PM
