Is anyone running this combo??
Old Jan 2, 2009 | 03:51 PM
MKW's Avatar
MKW
89 4x4 Pickup
22re
5spd
4.88s
35" tires
I know that 5.29s are best for 35s and 4.88s are best for 33s, but how bad will 35s and 4.88s be on the freeway?? I've been running 4.10s and 31s for a little while will it be similar?? I'd really like to hear from somebody that's running this combo. Thanks
Mike
Old Jan 2, 2009 | 03:55 PM
muddpigg's Avatar
Think 4crawler is running a similar set up.
Old Jan 2, 2009 | 04:03 PM
Issues's Avatar
i have a friend running that gear ratio with 35"s and it does fine. We have some big hills around here and he pulls them good in 4th. And it does good in the woods. It doesnt crawl like it would with 5.29's but as far as power & grunt its good.
Old Jan 2, 2009 | 04:36 PM
swapped89's Avatar
a friend of mine has a 4runner with that set up. he sais its good on the HWY.
Old Jan 2, 2009 | 04:39 PM
Erik Hinch's Avatar
I have run that combo before. you will find that on steeper grade on the hwy, you'll have to come outta 5th more oftern than with 31's or 33's, but 4.88's and 35's are no problem. Heck I even ran 4.88's with 38s and 39.5s, and could easily smoke a stocker on a hill.
Old Jan 2, 2009 | 04:53 PM
myyota's Avatar
Im building my 4Runner right now, and i will be running 4.88 gears front and rear on 37'' tires, i also have duel cases and a Detroit locker in the rear and ARB in the front.
Old Jan 2, 2009 | 04:58 PM
Beaniam's Avatar
good to know, I have 4.88's and will soon be running either 35's or 36's
Old Jan 2, 2009 | 04:59 PM
86Toyrunna's Avatar
yup, im running 4.88s and 35in mtr's.. does good..tryin to pull 4th gear larger hills it dogs down if you dont have alot of momentum. other then that. im at about 2100rpm at 50-55mph in 5th gear. i havent really got it up past that sence i did my sas.. i dont do alot of freeway running, no need to on my daily commute.
Old Jan 2, 2009 | 05:02 PM
MKW's Avatar
MKW
thanks
Thanks a lot. My truck got a little bigger than expected and I think it needs 35s instead of these 33s. Now, I've just got to sell my KM2 33/10s and get some 35s!
Mike
Old Jan 2, 2009 | 05:14 PM
Ironmike4x4's Avatar
I plan on running 5.29s when I get finished builing my motor for my '87 pickup with 35" tires. From what I've researched that's the best combo along with 4" suspension and 2" body lift.
Old Jan 2, 2009 | 05:21 PM
MKW's Avatar
MKW
I just got finished putting a 4" suspension lift on my truck and I've got all kinds of room with the 33/10s. That's why I think it needs 35s. What I'm saying is...I don't think you will need a 2" body lift, unless you just want one.
Mike
Old Jan 2, 2009 | 05:31 PM
Well that is certainly good to know. From what I've searched on here that's the combo you will need to have for 35" but if that's not necessary then I'm all game. I will be subscribing for updates on your build. BTW what part of GA are you from? If close by then maybe after I get my truck done we can make a run somewhere.
Old Jan 2, 2009 | 05:49 PM
Issues's Avatar
My 86 fourrunner sports a 4"in suspension & 3"in body, duel cases with twin stick, 5.29 gears, Aussie locker front & full spool rear, 35"in Mud King tires. And it pulls great on the highway & great in the woods with just one t-case engaged in low. Just waiting for spring to install the solid axle under her. Only problem Ive had is breaking the front inner axle shafts. But this only happens during wheel hop or real bad binding...
Old Jan 2, 2009 | 07:27 PM
BigBluePile's Avatar
I have 4.88/35's combo and haven't had any issues as of yet. It pulls better than it ever did stock!
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
