- Spring Upgrade/Swap - 87 Pickup 4X4
- 1989 pickup flasher location please
- 89 centerforce clutch- t/o bearing
- Electic fans?
- Newb Q: front rebuild
- 94 p/u speedometer probs???
- knock sensor
- How do you relocate blinkeres into parking lights?
- Your thoughts on steering pump replacement
- Input on Input Shaft
- Torsion Bar Help
- Adding rear defroster. I have questions, need answers
- Noises from rearend
- Belt tensioner pulley bolt
- polyurathane tranny mounts for my 87?
- Replaced alternator, now truck has no power at all...
- injector cleaning ?
- fuel pressure regulator
- Truck has power but will not start. Help!
- Fasten Belts dash light comes on, on the freeway!
- Curbed the rear and now it's noisey
- Automatic transmission is hard to shift out of park and doesnt line up right. Help?
- Cluking noise when coming to complete stop
- New oil leak
- over heats with ten mintes twice then is fine????
- 1987 yota 4wd VSV Valves w/Pic
- 1986 4runner 22re turbo electrical problem
- Help with doors
- Need help in the Ft. Lewis area with a ticking sound...
- Throttle Position sensor ??????
- Another HG bites the dust.
- Unknown part (pic inside)
- quick and cheap 6.5" speaker enclosure first gen 4runner door panel
- Tie Rod and Idler Arm
- Maf sensor problem??loud airbox
- 91 4runner Cold Start problem
- Valve Cover Baffle?
- '86 Pickup Fuel Tank Sender 22REC
- Axle retention clip
- 22re Exhaust Flange?
- Pitman Arm stuck
- GM alternator into '91 V6 pickup - wiring question
- 21r engine build
- Fixed my gas guage
- 1994 Toyota 4 x 4 SR5 package
- need help with diagnosing no start issue
- 3VZE w/ 24v '92-'93 Camry heads-project posted/started here a while ago...can I do it
- Kosher Oil pressure for a 3VZE...lowers a lot when hot! + oil viscosity + consumption
- 94 valves?
- 1st gen Royal Blue 4unner availability?
- Instrument Cluster Issues
- More head trouble on 89 runner 22re
- Diff Armor Large vs. Small
- OBD1 2nd gen 4runner
- Wheel spacers, how safe ?.
- Replacement Intake Tube!
- Just finished custom front bumper for my 94 truck
- fender accessories
- Main bolts
- fuel damper
- 3VZE AFM adjustment
- 22re fuel line size
- replaced o2 sensor still has code.
- Heater Core: Regular or 'Heavy Duty'?
- Brake ?? after lift
- '92 Pickup w/ 3VZE - Lacks low RPM Power
- Mechanic re-used headbolts, do I need to replace?
- Idle speed high, then low
- can 2 injecors go at once, or is it somehting else?
- Rear Suspension OME + Bilstein....1 ton
- Digital Camouflage rig?
- ARB bumper on 2nd gen?
- 88 22re injector
- 88 4Runner Bikini Top
- Help! 3 out of 6 spark splugs have been hela coiled.
- rear axle leak, w/ pics
- AS Reed Valve Question
- Frozen Key Barrel
- Where does this bracket go?
- 90 toyota PU 3.0 wont start... HELP!
- #3,4 Cylinders Cold Not Firing
- shackle lift
- Quick TPS question
- Hard gas pedal!
- El Cheapo Alternator Upgrade for 22RE
- eBay rebuilt V6 3.0 3VZE
- No more surging
- rebuild or crate engine??
- how big are 86-88 ext cab rear seats?
- Need Diagram Or Pictures!
- 1992 4Runner SEATS/OPTIONS
- Rear seal bolt sizes
- 2nd Gen 4Runner HID Install
- Amsoil Severe Gear
- is $850 to regear w 4.56's a good price?
- How to Change VSS?
- Lost overdrive
- Change my 88 4runner starter
- trailmaster 4way ,shocks that is
- Engine wont run right!
- Tranny ID
- turn signals don't work - 88 4runner
- 4Runner rear window motor.
- timing issues
- strange squeeling from 89 22re *help*
- Wiring harness swap
- 3vz intake manifold, hoses, and upper injection diagrams
- no fire on 91 4x4 v6 manual truck
- Blown HG:( 93 4runner- options?
- Starting issues
- 87 toyota pick up.Wont start now.
- V6 3.0 EFI question
- 1990 SR5 4runner has no power!
- torsion bar, or what else
- 87 22r prepurchase questions
- 3VZE power!
- 91 22re 5 speed clutch/transimission problems
- Rear Deflector Mounting Pic Needed
- super bouncy front end, newbie needs help
- Split Rear Seat Won't Fold Down 87 4Runner
- 86 Door Panel Swap Write Up
- parts interchange question
- 86 4runner starting problems
- Driving without a truckbed. Help with Lights.
- Misfire after 2k
- Checking Codes
- rear brake seized when i tried to take off the drum now it wont turn at all!
- ATV in the bed...
- best cam for 22rte
- POPQUIZ?electrical issue
- Corner bulb replacement
- ?Radiator cleaning?
- engine light
- Alternator Toast?
- The 2700 rpm idle issue UPDATE question.Ok so I replaced the IAC and still had this i
- 1990 toyota 4Runner power problems
- 4wd light wont come on
- Rebuild Health Check Time
- power loss,bog and braking problemes
- 22re to 22ret conversion?
- Intermittent problem over 70mph?!
- How to clean EGR valve?
- sputtering, hesitation and no power
- Dash lights and climate crl lights?
- 3.0 header owners, I just picked up some used Downey headers, got a few questions
- rear diff help please
- How was your guys alingment after 1.5" BJ lift
- Front Differential Assembly Replace
- Need to replace steering box
- What's Wrong With My Temp Gauge?
- Some Pics of my 4Runner
- 1989 toyota pickup
- 86 Toyota pickup 4cyl over heat with no heater
- 22re exhaust manifold removal help
- Fuel pump? 3slow
- New (to me) 94 4Runner
- Cracked Block!?!
- Need advice 4x4 not working
- 22RE fan runs constantly
- Bad Catalytic Converter? Pictures! How do I tell?
- Tube door question
- '90 efi... Flooding out
- Clutch help needed ASAP
- NO cold starting--? Starting Timer Injetion Switch 94 4cyl.
- Looking for pitman shaft seal part number
- 93 22re missing
- SAS Questions
- Auto To Manual Swap Question
- Replaced Idle Air Control and still have a 2700rpm idle
- '88 Man. Transmission Problem
- Pic request: 1st gen 4runner pass seat
- Window Felt for 4Runner or Pickup!
- Un-used harness connections (pics)
- Anyone actually got the IAC/AVV of the bottom of the throttle body?
- Do you still have neutral in the t-case with twin sitcks?
- 93 v6 4Runner Build thread / Timing issue
- Transmission ID without a firewall plate??
- New Shoes and Lights! Busted Shock! (pics)
- power loss, clueless on what it could be
- Transmission O/D light flashing
- the right head gasket
- 1994 22re coolant leak, back of block
- 1987 toyota 4runner frame and parts
- rear cab light mod
- Gear selector won't move
- 22re Oil pan issue, idle issue...
- Another 2nd Gen!
- HID Light options for 1st Gen 4-runner?
- Saggy rear end
- TPS Adjustments?
- 4runner Seat Slider Repair
- Timing chain wont fit!
- 93 3.0 no codes terrible gas mileage
- '92 4runner V6 - misses and dist. noisey
- SAS Front Shackle Question
- Intro/Advice
- Parking brake cable?
- '87 4Runner - O2 Sensor Installation
- Leak from bottom of intake. Suggesstions?
- Stuck in 4 Wheel Drive
- What function does the #1 speed sensor perform?
- rod bearing problem
- Is it possible to install a cam without taking off the head?
- check engine light
- 22re back pressure problems
- 1986 4runner 2nd Gen Canopy
- another 3vze/cold start/rough idle issue
- Power/Start problems
- questions about a rookie offroad driver?
- 4runner Door Alignment
- window track and heater leak
- Runs fine cold, not warm
- Shorting the Timing check Connector
- Stalls after 1/2 mile
- Triple Cases??
- idling at 2700 RPM!!!
- Coolant leak possible head gasket.
- weird engine trouble
- 1990 Suddent Loss of Power
- toyota turbo truck
- interpreting VAF readings
- Skid Plate with a lift?
- is $500 for a blown engine, trans, trans case etc a decent price?
- engine rebuild parts
- interior swap - sliding sunroof headliner removal?
- Solution to my bad engine...
- Oil Pump Question
- Center Console Options
- PAIR Removal
- Warn front bumper question
- 1992 3VZE 4x4 4Runner engine removal
- Custom Dash
- rear suspension question
- Oil dripping from passenger side of engine
- Speed sensor for a 94 pickup
- 89 4x4 Transmission removal... seems to be stuck?
- E-locker Question!!!!!!!!
- Auburn LS up front (IFS)
- Can you mount a MAF/VMAF/AFM sideways?
- Help! 89 Pickup 3VZE drops fuel pressure at at 3500 RPM or WOT
- brakes sticking issue
- Installing A/C...pulley issue
- Strange surging/idle problem
- New to me 91 4X4 Ex Cab 22RE 5 spd
- Transmission woes
- 1987 t1000 xtra cab HELP!
- Manual Hub Problem
- 22re engine feels like no power!! HELP!!
- need expert help, upperend noise
- Motor Ground...
