the right head gasket
Old Jan 28, 2010 | 11:26 PM
whitekingsnake's Avatar
I am pretty sure I have the correct head gasket for my 86 22re 4runner. I got it from toyota. What I am seeing is when I put the gasket on the block the round coolant passages next to the bolt holes get covered up by the gasket.
The head has the corresponding holes but there is no way for the coolant to go from the block to the head, Has anyone else noticed this?
Old Jan 29, 2010 | 10:15 PM
abecedarian's Avatar
The head gasket will block holes that Toyota has deemed unnecessary for coolant flow under normal conditions. High-performance engines may require coolant passages be exposed that aren't otherwise used but an appropriate head gasket for those situations will expose those passages.
What you need to be most concerned about are the oil passages between the engine block and head aren't occluded.
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
themightykhoner
Aug 11, 2015 07:37 PM
Coreyr384
Jul 10, 2015 11:13 AM
