How to Change VSS?
Old Feb 2, 2010 | 07:21 AM
ak_md1122's Avatar
How to Change VSS?
hi,
i have 1990 P/U 4WD v6 that is showing a 42 error code. according to the book this is the #1 vehicle speed sensor.
from what i can see the VSS is easy to get at. can anyone tell me what is involved in replacing it?
i've attached a photo of what i believe is the VSS. correct?
once i unbolt it how are the wires removed?
thank so much.
-m
Old Feb 2, 2010 | 01:49 PM
MudHippy's Avatar
I'm pretty sure that's not the vss. It looks alot like the speedometer cable to me.
The vss should be inside the combination meter(speedometer/odometer/vehicle speed sensor) in the dash.
Not easy or cheap to replace. It requires removing the steering wheel, the entire dash/console, and then removing the combination meter with the vss. The entire combination meter must be replaced as a unit, the vss is integral and can't be serviced or replaced by itself. The combination meter costs around $125-$150 new, and is a dealer item(only Toyota makes 'em).
Good luck!
krimsonone
Sep 13, 2024 09:33 AM
Dennisx2
Aug 10, 2015 06:48 AM
accuracy
Aug 4, 2015 08:05 PM
Dennisx2
Aug 4, 2015 01:26 PM
wilbertd
Jul 6, 2015 07:39 AM
