timing issues
Old Feb 1, 2010 | 08:24 PM
kdogy313's Avatar
timing issues
I just rebuilt the top end of my motor and the timing seems off. I have tried the distributor and that doesnt seem to quite do the job. is there a sure fire way to tell if it is the timing belt?
Old Feb 1, 2010 | 08:26 PM
DeathCougar's Avatar
Just make sure you have the timing marks correct. Ie, set your mechanical timing first. Then, move on the distributor timing. Its not uncommon for someone to get the distributor in one tooth off.
With the crank at top dead center (aka 0 on the timing cover mark) your cam hash marks should be right on, and the belt will go right on as well.
Old Feb 1, 2010 | 08:57 PM
RMA's Avatar
RMA
did your timing belt have marks on it or was it one with out marks.
its pretty easy to think you have it lined up right but not really have it right.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
