over heats with ten mintes twice then is fine????
Old 02-04-2010, 10:54 PM
drysuperfly's Avatar
i have a 86 runner 22re fuel injected.... i just replace thermostat and did a coolant flush and every time i start my car from a cold start and start driving it will over heat, (then i stop and let it cool down) then i will be off again, and i will come close again. Usually after that its fine, my temp guage varies but stay good the rest of the time... i talked to a few toyota techs that said they dont think is the head gasket going.. any ideas?
Old 02-04-2010, 10:56 PM
totally a bro
Staff
vital22re's Avatar
hows the fan clutch? cold spots in the radiator? air in the system?
oh and corey https://www.yotatech.com/forums/f5/d.../index132.html thats our bs chit chat thread
Old 02-04-2010, 10:58 PM
toyota4x4907's Avatar
did you purge the cooling system of all air after replacing the thermostat?
Use OEM t-stat? try replacing it with an OEM dual stage or try drilling a small (1/16 or so) hole in the t-stat.
Old 02-04-2010, 11:04 PM
how do i check the fan clutch? or purge the air?................i've heard of the dual stage thermo and i went to the dealer to see if they had one and they had no idea what i was talking about
Old 02-04-2010, 11:42 PM
totally a bro
Staff
vital22re's Avatar
2-stage thermostat, Toyota P/N: 90916-03070 try the dealer now. I can talk to my guy at tok and see if he's got one
Old 02-05-2010, 12:44 AM
Staff
Terrys87's Avatar
I have an 87 22re and it was doing the same thing. I flushed it,t-stat and about everything else. Finally I took it to a radiator shop and they were able to flush it with high pressure and it looked like mud coming out. These radiators are old and have alot of build up in them.
Old 02-05-2010, 12:55 AM
Truckfiend's Avatar
Just cause you got a new thermostat doesn't mean you got a good thermostat. I'd start by getting another thermostat. They are cheap. I've had the same problem with new thermostats.
Old 02-05-2010, 06:30 AM
allnmstkn313's Avatar
Try a new thermostat for sure. Parts stores also tend to hand out thermostats for the wrong temp.
Old 02-05-2010, 08:44 AM
tim a.'s Avatar
My truck had an every now and then runs hot problem.Cost me a head gasket for ignoring it.Change that fan clutch.
Old 02-05-2010, 09:13 AM
kiyobrown's Avatar
The titus will in Tacoma has at least one more in stock. Don't ask me how I know.
Old 04-12-2010, 02:21 AM
agentmantis's Avatar
replace the thermo..
My truck was doing the same thing. I had a fresh rebuild and it kept overheating. Until I could find a Toyota two stage thermo I just drilled a small hole opposite the valve side on the parts store thermostat. It worked and my truck stopped overheating. Later I got a two stage and installed it and it works and no overheating. I've been driving it like this for over four years and the temo gauge never budges from it's normal LOW spot. I really think that this common thermostat problem is the key issue with so many 22R/E headgasket problems.
Fan clutch is a very simple and relatively cheap fix if the thermostat doesn't work out.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
skebe22RTE
07-31-2015 02:03 PM
PlayAwhile
07-20-2015 11:36 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: over heats with ten mintes twice then is fine????
