Dash lights and climate crl lights?
Old Jan 30, 2010 | 06:06 PM
martyMcfly88's Avatar
I picked up a 91 runner and the dash light dont work or climate control lights i tryed a new relay and no fuses are blown could it be the bulbs or wiring?
Old Jan 30, 2010 | 06:11 PM
dntsdad's Avatar
Of course it could.
Have you tried turning the dimmer knob on the left side of the steering wheel? I have seen people tear into the dash only to realize this was the issue.
Illumination wire is green in toyotas see if you have power to any green wire in your dash. Also, I dont think the fuse is "hot" unless the lights are turned on. Did you check the fuses with a meter or test light with the lights off? turn the lights on and recheck.
Old Jan 30, 2010 | 06:18 PM
ok i will look into that.
i have a retarted question how do i get the dash off lol
Old Jan 31, 2010 | 07:22 AM
dntsdad's Avatar
there is a 10mm bolt on the bottom left above the lick panel, next to the hood release and a series of screws. that will take the bottom piece off and then go from there.
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
ty1er
Aug 1, 2015 11:53 PM
PopsDad1
Jul 30, 2015 02:21 PM
rushw
Jul 18, 2015 01:46 PM
