- R150F Transmission Going Out?
- Will a header help my 22r?
- Amsoil Diff Fluid
- Pull engine and trans together?
- 3ve starting issues
- 3.0 Front Driver Side Cam Seal Leaking. NEED HELP!
- 93 Toyota Truck 4 cyl. 2 wd Clutch Problem
- Idle air control valve for 95 Toyota 4 runner v6
- Auto Trans Not Falling Into Gear
- 86 toyota pickup 22re will not turn over
- Watt question
- 22re throttle sticking bad!!! Need ideas
- no front brakes, rear lock up?
- New guy new truck needs help
- 22 RE troubleshooting
- What are these gaskets for?
- 1987 4 runner brake issue
- when flying at 75 mph does your 5th gear feel like it has power?
- 92 toyota pickup provisioning valve
- v6 fame vrs.4cyl frame
- Warped rear hub
- Another cooling system thread :(
- 93 yota 22re keeps stalling????
- 3.4 Swap ECU Compatability w/A340H and Late Model Mill
- Pulling 22R block with head off?
- 94 3.0 swapping in 02 3.4 Have a few questions please
- DLX gto SR5 gauge cluster questions HELP
- Getting rear tailgate window down without power?
- 86 4Runner Idle Air Control Valve
- Is the lean drop method good enough for smog?
- 93 PU sr5 brakes not building pressure.
- Warm 22RE Problems
- HELP! 22R-E leaking oil like a sieve
- The build continues 91 4X4 22RE
- '95 4runner shift problem HELP/ADVICE
- 1990-2000 4runner paint job
- IFS Power Steering Box Seals Discontinued?
- 94 Toyota Pickup V6 3.0 Headache
- 95' 4runner transmission problem?
- 20mm or 23mm Input bearing for my G52 4x4, need to order kit.
- 94 4Runner 3vze
- 86 4 Runner idling issues
- Zuk on 2wd causing yoke grind?
- 1994 4x4 V6
- thule 400xt roof rack on my 1st gen
- Foolishly bought a bad truck, need opinion on overheating and rust
- HELP! Front turn signals blow signal fuse
- odd idle on a 3.0
- Seeking Advice for full suspension rehab 92SR5-V6-4WD
- split cv boot--compatible parts
- Supra AFM swap rough cold idle
- How to keep stock battery gauge, GM alternator
- 95 4 runner power steering fix
- 22re street rv and 268 cam valve lash
- What is this and what is its function
- w56 apart and will not go into neutral
- Where tube caps end up when they fall into the engine bay
- Cigarette lighter not working
- Not sure what caused this?!? Broken fuel pump bracket
- Project
- 22r Knocking top end
- CAD 1987 Toyota Pickup
- Need Help Installing Torsion Bars
- 2nd gen 4Runner body swap
- Piston Ring End Gap 22re
- Slave Cylinder Boot Full Of Pressure/Fluid
- Door panels (interior) 1986 22r
- 1990 pickup v6 3.0 4x4 help needed. won't start after warmed up
- suspension travel
- 22re throttle surge/pulsating
- Finding Oil Leak - HELP!
- rear suspension recommendation
- ac install help
- I got my truck back after I sold it! What a relief.
- Spark plugs smell like burnt electric motor
- Checking crankshaft timing mark
- Alternator problems
- 1986 22RE 4 runner- won't idle
- oil leak on a 3.0 ltr 1990
- Remove leaf from OME rear
- Vacuum line replacement, silicone or oem?
- Head gasket??
- Power steering eruption from cap
- 91 3.0 Makes Noises
- question about rear driveshaft
- 22re downpipe glowing red
- radiator question--22re
- '89 Toyota pickup power steering gearbox leak
- valve adjustment on 94 22re- what did I mess up?
- Sliders and Rear Bumper
- torque converter? tranny?
- 4.30 ratio rear diff
- Needing to replace front leaf springs
- Tachometer wiring
- 94 4Runner cruise control
- 90-94 engine swap to late model v6?
- transfer case issue
- Any Experience With Online OEM Parts Dealers?
- Where do A/C VSV Vacuum Lines Hook Up?
- help rattle from new clutch
- 1992 Aisin hub
- Battery dying
- Air Conditioning
- 93 Toyota 22RE will not turn over
- 88-91 3vez swap distributor question
- 3VZE loss of power at elevation
- Adding A Tach And Volt Meter
- Fuel Cut Solenoid Valve O-rings???
- Aftermarket Anti-Theft System Removal
- Fiberglas vs. steel panels
- Royal purple in half rebuilt engine?
- 22RE Rear Dually 4x4
- Oem coolant temperature switch vs aftermarket?
- Gear oil fill bolt
- 4runner only moves in 4LO, help needed
- Wiper Woes
- "Stumbling" while maintaining speed
- PYRITE MICA for 91 toyota pickup??
- 3vze 1988 into 1993
- 22RE harmonic balancer bolt seal ?
- Are all fuel filters created equal?
- A340H Kickdown cable adjustment
- 1988 4unner simple power gains
- Valve Cover Gasket
- overhaul with annoying vibration/ fast clicking sound
- Plastic Chunks in Oil Pan??
- 91 3vze major oil leak from the headgasket?
- 95 4runner v6 automatic issues
- 1990 4runner 3.0 fuel electrical issue
- Grrr... our IGF isn't Working
- 22R Fuel cut solenoid issues.
- 86 toyota 4runner 22re
- 3.4 swap in a sr5 truck
- Please help me ID 22R carburetor adjustment screws (Pic)
- great... ANOTHER TPS...fml
- taking battery cable off
- why wont you start????
- 93 Pickup Fuel Filter seized
- 92 toyota pickup. 22re wont start
- Knock Sensor Test?
- PICS WANTED: charcoal grey or any new paint job done
- hello again, I come bearing gremlins
- Forerunner drive shaft in a pickup?
- Timing chain guide question
- Brakes Sometimes Do Not Always Release
- Door hinge pin replacement.
- Clutch replacement now no 5th gear.....
- 88 3VZE Help
- Looking (who would have thought)
- help me figure out the steering wheel!
- 22re idle question
- can i swap 98 tacoma springs to my 93 t100?
- 93 Toyota pickup auto trans problem!
- Brake pad and rotor recommendations - 91 4Runner v6 S12W
- 1994 Toyota Pickup
- 93 sr5 3vz-e
- Rear diff gasket replacement.
- 22RE - Unknown Sender
- How to install tcase shifter
- 87 Pickup loose CV
- Clutch Replacement Tips?
- 22re High idle and surging while braking
- code 42 1989
- code 42 1989
- !987 Toyota Dolphin issues
- '93 3.0 Muffler Suggestions ???
- '86 4Runner Leaf spring assembly question
- 1992 toyota Pickup No Overdrive
- 22re Where to go from here?
- Burning but dont know why.
- My 1989 Crazy Train. Warning this truck is cursed and I need advice.
- OverHeated!
- window regulator tabs
- Shift solenoids or...? 89 pickup 3.0
- Vacuum Line Question
- 94 Throttle Body / Dashpot Question
- 87 4runner wont start
- 88 22re wont drive above 35mph
- 22re dialed in!!
- Weird white smoke problem
- how do you translate brake caliper casting numbers
- 87 4runner o2 sensor part #
- 1987 4 runner needs new engine
- '94 p/u power issue
- Rebuilt 22re first oil change
- 87 22r Oil in Radiator and Antifreeze in #1 cylinder
- Need help getting my Yota going
- fan on a 3.0
- smaller ball joint spacers, less problems?....
- 3vze random stall
- Help!! Power loss.major.
- Open to suggestions....timing
- help with wiring harness connectors!
- Brake pedal turns right turn signal on when brake pressed?
- 1994 Toyota P/U 4WD 22RE
- need advice on new wheels
- Disc brake conversion and driveline ebrake?
- 1994 Pickup- buzzing/vibrating noise from firewall area
- 4crawler and the lift adapters they sell for my 91 4X4
- Fuel tank to fuel injector rail modernization
- Transmission Fluid Flush or Drain and Fill - 94 Pickup 3.0 v6
- 93 4runner need cheap lift
- Interchageable Front End Parts
- 3.slow
- 94 Yota Deluxe Spare Tire Won't Drop Down
- 1987 4Runner strange tap/knock in reverse
- Anybody Try GForce Chips?
- Best budget fender flares?
- Shocks - Brands
- Can't get my intake chamber off!
- help diagnosing rear end problem
- The infamous warm start issue
- Troubleshoot CV axle replacment
- question about center console/arm rest
- Heater pipe stuck on bottom of intake
- Front axle shaft install in the 91 4x4 pickup??
- Burned hole in axle tube
- VSV Curiosity
- 3vze knock sensor torque spec????
- Brakes stick after stopping???Wont release.
- rear defrost question
- 30mm main transmisson bolt
- Need 22re fuel pressure regulator vaccum diagram
- Fuel sending unit
- Toyota Pickup Clutch Question
- 2nd gen 4Runner (90-95) plate bumper with swing out tire carrier
- 3rz power problems!!!
- Lola's rebuild of a knocking 3VZE
- 94' Pickup 3VZ-E 3.0 won't Start when Hot
- help me 32 or 33? pics!
- 89 truck 3.0 engine failure
- new springs. questions about shocks
- A340H teansfer case, center support removal
- Does my transmission mount look correct?
- 1990 pickup tcase issues?
- 4 cylinder transfer case
- Baja style style 1st gen runner
- VSV Part Number
- !992 3vze heads problem
- questions need help with
- New here and seeking advice.
- Need a favor from someone with a first gen 4runner
- Well, I'm back with a new project:)
- 92 pickup, 22re, 4 cyl. rattle/tapping noise
- 1988 4Runner bilstein shocks
- rear axle shaft compatability?
- looking for used bed for 91 extended cab
- Flipped the heads over, all the valve buckets fell out!
- Cracked Seat Belt Fix
