torque converter? tranny?
Old Apr 21, 2015 | 07:10 PM
yota tay's Avatar
Hi. Newbie here who just became the owner of a 94 pickup with the 22re and auto. Bought the truck for dirt cheap with seized motor. Bought used motor and me and a friend of mine removed old motor with tranny still attached. Attached good motor to tranny with converter not seated properly, but did finally seat it correctly after some investigating. Added 7 quarts of atf to the empty tranny and the engine dies when I put it in gear. Did I not seat the converter correctly or did I mess it up. Is there any way I can try to reseat it? Is the tranny shot? It never heated the atf. I can see the driveshaft want to turn when in gear but it dies instantly. Forgot to mention that I didn't fill the converter with atf before I installed it...would that cause problems? Any help would be appreciated. Thanks guys.
Old Apr 21, 2015 | 07:17 PM
Heat Man's Avatar
So your not sure if the tranny worked before you bought the truck?
Will the drive shaft turn when its in drive with the tires in the air?
Old Apr 21, 2015 | 07:24 PM
yota tay's Avatar
To tell you the truth, no I didn't know if the tranny was working. I assumed it did because my friends dad owned it and said it was the head gasket. After further investigation I found the timing chain cover in oil pan and nothing but tap water in the radiator. First thing I did was drain all fluids out and the atf was black at first, then dark red at the end.
Old Apr 27, 2015 | 10:44 AM
yota tay's Avatar
Bump.
Old Apr 27, 2015 | 10:56 AM
scope103's Avatar
Originally Posted by yota tay
... and the engine dies when I put it in gear. ....
... Will the drive shaft turn when its in drive with the tires in the air?
If the engine dies when you put it in gear, I'm guessing the input shaft (connected to the inside of the torque converter) does NOT want to turn. Checking to see if the drive shaft will turn is easy and will tell you if the whole transmission is frozen solid (so yes, you should do that). But the driveshaft can be turned even if the torque converter is installed incorrectly so that the engine cannot turn the input shaft.
Old Apr 27, 2015 | 11:55 AM
yota tay's Avatar
Thanks for the help. Will get it towed to my house this week sometime and give it a more thorough look thru.
1uzRunner
63
Nov 10, 2018 03:58 PM
zz_denis
Sep 6, 2015 03:43 PM
Wardog
Sep 6, 2015 07:57 AM
eggens
Sep 5, 2015 12:16 AM
Nick Berg
Sep 3, 2015 04:36 AM
