93 4runner need cheap lift
93 4runner DIY Lift New Springs ect not full kit
I have a 93 4runner that is used to drive around town as well as on the trails in alaska. I don't want to dump a bunch of money in it as it has a lot of cancer. My question is what is the easiest and cheapest way to get a few more inches of height out of it. the rear is squatting bad as well. any advise would be great not sure i want to shell out the 800-1000 bucks on a suspension lift when i only paid a 1000 for the truck
i have thought about body lift but was hoping to get a little more suspension out of it. like maybe put taller springs and new shocks in rear as it sags badly. but don't know what size is good or what to do with front. Just know i need more clearance and i would like to put 33x12.50 on it
You could try a number of ways to try and get suspension but it really won't improve your suspension. Maybe a ZUK mod for the rear to level it out. But a body lift is probably your best bet for bigger tires. Maybe ball joint spacers up front and blocks in the rear. But that can be a lot of work depending on how rusted your front end it.
OP get some land cruiser coils for the rear to fix the sag cheap. If your needing room for bigger tires cut the wheel wells open more, already said it had rust.
thank you all for the advise think i will look into the land cruiser springs to start then maybe a body lift for the bigger tires and cutting the fenders is definitely a option. and i wheel on the kenai penninsula.
Front: adjust height via t-bars, within reason so you don't put CVs at a bad operating angle. Free.
Rear: add taller coil springs - land cruiser is a popular swap. $50 on eBay.
new shocks of choice. You can do all of this for very little money.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
skoti89
Jul 6, 2015 07:45 PM
