- No spark!
- 91 22re whats this noise???
- Will a bad tranny cause your speedo to be off?
- Ignition Switch Problems
- 95 4Runner 3vze acceleration problems! HELP!!!!
- 22re wont start
- Rear shocks 95 4runner what are you running?
- Steering Stabilizer
- Added two new yotas to the family this week
- Harbor Freight lights ?
- Bad front end grinding
- Won't Start
- 3vze top end knocking and dying when warmed up
- whats the piece on the front rear wheel well called?
- Rear seat rattle, 89 4runner, bushing??
- Fuel pump removal question
- Quick Questions about exhaust and CA Smog/Engine Timing
- valve tick question.
- Synthetic oil in an 87 22r with 160,000?
- New and '93 with RUST issues!
- 22re Idle issue when brakes are applied
- Oil Sending Unit Wiring
- 93 2wd v6 auto tranny /4wd conversion?
- 22r Fuel Issues
- Lets see your home paint jobs!!!
- On 3rd slave cylinder, why do they keep leaking?
- Transmission
- 83 tranfer case into an 87
- might have to replace engine...please help
- 4runner help. No clue where to start.
- Clutch Pedal problems 93 pu v6
- 1987 4rnr no crank or spark after warmup
- 89 tranny questions
- 94 factory tow hitch types
- Jacked up fuel mileage after new head gaskets
- Spark Plug Gap? - LC Engineering 22re
- Power Steering Box Replacement Write-up
- Help Confirming TDC on 22RE
- pumping brakes causes my 1986 toyota truck to miss
- Dur, what's this wire do?
- Sluggish 3.0!! Questions..
- Help with Air Fuel mixture? i think...
- Got my truck back, new gears (yeah!) and new issues (boo!)
- no fire need help
- How much did you spend on your 22re rebuild?
- 1988 22re timing issues
- speedometer cable part #
- W56 and r151f shifters......
- 89' Pickup 3.0 advice needed
- 87 4Runner surges when cold and accelerating
- electrical issues
- 90-95.OBX 22re header compatible with 87 4runner?
- 22r rough idle and backfiring
- Charcoal canister, Gas smell HELP!!
- 200k and Laundry list of items to fix
- Possible Vacuum Leak
- Clutch or Something Else?
- Old Man Emu cs0019r spring installed!!
- Fuel tank swap
- Repairs I made last weekend...
- 89-95 Bed Swap, What fits?
- Speedo, tach, and gauges all just quit...
- Ac belt not lining up.
- 22RE HG change while doing timing chain
- Brake pedal trying to kill my engine.
- Rough Idle and shutting off
- ignition coil interchangeability
- 93 cab swap, dash ideas?
- 88 4Runner and a performance chip
- K&N Cold Air Intake for 22RE
- Rear Window Switch Broken: How Do I Fix It?
- Engine Oil Leak: Anyone Know How To Stop It?
- Broken '86 Power Antenna How To Fix?
- CO Relay Question
- Clicking noise, unable to locate
- Fuel Sending Unit question
- electronic to mechanical speedometer ?
- rough idle, bad mileage
- Rear U-bolt sizing??
- Tach and A/C cutting out...
- Water pump.
- 87 4runner Rear Window problem
- stock exhaust help
- 1986 22R California Vac issues
- Safari snorkel for 1989-95?????
- Poll: Tailgate Decal
- 88 4runner 3.slw build...Wake the beast inside?? lotsofpics
- 3VZE won't rev up after head gasket replacement
- A340h powerless!!!!
- Drivability Problems...
- A/C expansion valve
- carb or? 22R 87 4wd
- 4runner throttle cable installation
- Engine noise when cold and accelerating
- Mechanic in Jacksonville, FL area
- 1995 toyota bench seat fit in 1986 toyota?
- resurface clutch disk?
- Weird 22re behaviors (videos)
- "Big 3" Mod on '87 4Runner
- I had a 3.0L oopsy
- why oh why won't it start?!
- 3VZE wont start after rebuild... HELP!!!
- Timing chain too short or off sprocket need help?!
- Steering box question
- Ball Joint or Bushing
- Shocks through bed in 4Runner
- W56 Bellhousing removal
- Lifting a 95 Toyota Tacoma
- will a 94 3vze work where a 91 3vze sat??
- Zuks, Tbars, shackles, BJs
- IFS BJ spacers, Upper & Lower Balljoint removal / install
- Ford door locks.
- Driver's side engine mount
- where can i find a 261c cam?
- ECT Computer Location
- Help removing lens from Gauge cluster..Tips on recalibration !
- 3vz failing smog no ac and code 51.
- 3VZ intermittent starting problems
- 87 22re Hard start when warm/hot
- CEL and O/D OFF lights
- Oil gauge not functioning...possible solution as to why it won't work
- need 22re isr mod write up
- Coolant Outlet Seal?
- brake booster?
- 1987 toyota pickup ac cycling switch
- she is back and running great!
- bad vibrate from shifter!! help plzz
- supra lsd axle lenght
- Front and Rear ARB Install Complete. Bravo Zulu
- No throttle response!!!
- RPMS Drop and Car Shakes When Warm
- How Long is Your Clutch? (Lasting)
- '89 4x4 w/ 22re engine: Trouble Code 12 - RPM Signal
- Can computer problems conflict with the transmission in a 95 4runner?
- Fuel Leak & Repair
- EFI fuse blown, Can't jump fuel pump
- Strange idle '93 Toyota pickup 22re
- Blown Engine - 3.0L - Need Opinions, Options
- speedo and gears 86 pickup
- options for modifying those exhaust flanges?
- Radiator reservoir bubbling.....troubleshooting help?
- Fuel related?
- Could my high idle be related to a cooler temperature thermostat?
- How to get rhino lining off of truck
- CEL Code 4
- 1994 3vze starts then stalls
- Throttle sticking at idle
- Fuse box ignitor etc inside cab
- 1995 3.0 5 speed slips only in 4th gear
- 90 toyta truck V6 starting problem
- just picked up 93 toyota pickup - stuck engine
- Read Gear Paint on 7.5 front diff?...Thanks
- Brake problems
- 87 Rear Window Channel
- burning rich
- 92 yota 2.4 running rich
- 22re stock exhaust downpipe: Stainless??
- 3vze: How to test injectors at home....
- Quick Fitment Question--Fan Shroud
- Error code 63
- '89 Rear Bumper on a '91 - Will it fit?
- Plastic interior panel plugs/size??
- After engine swap only running on front 2 cyl. !!!Need help!!!
- w56 rear seal retainer housing
- 86 vs 92 big issues
- 90-95 4Runner TAG ( Formerly KMA ) Rear Bumper
- v6 and auto trans to 22re and manual swap.
- Help!!! Rough Idle White Smoke From Exhaust 22re
- Brake related Vacuum Whistle
- cant locate source of major oil leak!
- clutch engage question
- front end inspection/refresh questions
- Big nut on rear of transfercase question
- Lets talk ecm,s
- 3.0 Liter overheating after new head install
- 1994 Toyota p/u 3.0 is idling rough and has a miss
- 1stgen 4Runner rear bumper w/ tire carrier
- Will not start...turns but doesnt start
- Intermittent starting problem.....Help!!
- tacoma seat fitment ?
- Royal Purple 10w/30
- Disc Brake Swap... Mill the Axle Flange
- Cruise Control
- Part Number
- SR5 Gauge Swap
- Is tranny mount 1 piece?
- Doesn't want to start in the rain
- uneven misfire, any ideas?
- 1994 3.0 engine rebuild
- 94 4runner help identifying hose
- Question about Tcase leaking through rear output shaft
- anyone running summit racing nomad wheels?
- 89 3.0 build thread
- 94 22re timing issues
- Strange Yellow Wax-Like Mess on Right Side 22RE
- 22re help needed!
- A340H pressure cable HELP
- 3VZE turbo
- New decal idea --- "Mud Gauge"
- rough spot on rebuilt steering box?
- Fan Clutch Tech
- A/C Problem
- Drive-ability
- Odd starting problem
- 22re knock sensor question. Compatibility ?
- AFM Woes
- Bad Camber! ideas?
- weird front vibration
- crankshaft notch and crankshaft pulley notch (pics)
- Is this normal 22RE operating temp?
- weird grinding sound
- 82 front grill on a 1991
- Setting ride height w/ a Blazeland
- 1993 22re fuel system problem
- Will it start w/o coolant hoses and fan/PS belts?
- First start of the day sucks, after that OK
- overheating 22re questions
- Timing mark on crankshaft not lined up with "0"
- how to adjust lspv rod?
- Custom Air Box?!?!?
- mixed plug wires
- distributor rotor at TDC?
- More issues with the 3.0 V6
- Accessory Terminal wiring help pls
- Can't roll up windows-crossed door wires
- 3vze swap, idles fine, but no throttle
- Usa standar gears??
- 86 runner leaking auto trans
- IFS Carrier Drive Shaft Bearings
- Replacing my clutch. I have a couple of questions, with pics.
- Power loss when a/c on? help
- Toyota 3VZE woes
- 3VZE valve check/adjust
- Grille ony 1986 Toyota pickup sr5 xtra cab
- sr5 gauge cluster
- testing cold start circuit, NOT injector
- 4Runner dies while Driving
- 89 4runner ebay black projector housings and 10000k hids( lots o pics)
- new 2nd Gen Runner owner
- Where do I hook up the fuel pressure gauge..
- clutch pedal shake
- Starter issue. doing nothing when key is turned
- Pick up coil??
- regular cab owner, how do you carry your rifles
- Steam/smoke from vents
- leaf springs in 4 runners
- Did the e fan swap
- cel crazy!
- Exhaust work...
- 2in lift is on. Thanks to all those who answered my questions!
