rough idle, bad mileage
Old Aug 20, 2011 | 05:34 PM
old4runner's Avatar
My '89 has been idling rough and had bad (11mpg) mileage a lot of what I was reading in this forum suggested that I probably had TPS adjustment. After checking and rechecking my tps I finally decided that TPS just wasn't it. I finally figured out (with starting fluid and a rag) that the issue was a vaccuum leak at the cold start injector, once I fixed the vacuum leak my mileage jumped 5 mpg and the idle is as steady as can be, but a little high. Anyway I thought I would contribute this post hoping that maybe I would help some poor guy who is fighting a similar problem and is likewise reading a lot of old threads that suggest his TPS is out of adjustment.
Old Aug 20, 2011 | 07:59 PM
dktool's Avatar
I too am experiencing piss poor mileage and my tps has been checked and adjusted per the manual.
If the ox-sensor is bad, will it cause issues WITHOUT throwing a code or check engine light ?
The truck starts and runs great but the tailpipe is black and the mpg is around 11
It recently passed a smog check with ease and the readings were no were near the hi limit on any of them.
Any thoughts or do these 3.0 / auto combinations just SUCK ?
Old Aug 22, 2011 | 10:10 AM
dktool's Avatar
anyone ?
Old Aug 22, 2011 | 10:39 AM
TNRabbit's Avatar
Originally Posted by dktool
anyone ?
Dang, dude; chill! People work around here~
Poor fuel economy can be MANY things, including:
-Vacuum leak (most common)
-O2 sensor (doesn't usually give check engine light)
-Cold Start Timing Switch (tells the engine it's warm)
-Leaking cold start fuel injector
-E-brake sticking
-There's a sensor inside the TB that coolant passes through; if block or otherwise faulty, it can make the ECU believe the engine is cold & cause it to run very rich.
There are others I'm sure, but that's all I can think of at the moment.
Old Aug 22, 2011 | 11:35 AM
dktool's Avatar
Does the cold start timing switch only tell the ecu to keep firing the cold start injector until it reaches a certain coolant temp or does it put the ecu into open loop and screw up feedback from other sensors ?
I have no vacuum leaks
The e-brake is not dragging
The ox sensor in an unknown at this point
Timing is correct
Does a 91' TB have the coolant sensor you mentioned ?
The only electrical connection on mine is for the TPS.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
_Nicco_
Aug 28, 2015 07:26 PM
