PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 [258] 259 260 261 262 263 264 265 266 267
  1. getting the oil pan off
  2. Cotton Pickin' HG
  3. Push button ignitions
  4. anti knock sensor 22RE
  5. Will Boring out a 3.0 help with power and mph
  6. One cause of head gaskets blowing
  7. Instrument cluster not working on my 88 4runner
  8. Cat Converter
  9. Tranny leak
  10. Tranny Jump?
  11. reving motor during driving??
  12. Subdued, Shinier, Stronger, Brighter, and Still Slow
  13. help-stripped exhaust manifold bolt
  14. How can I improve the gas mileage on my 3vz?
  15. 95 4Runner Idle and Rough running
  16. Timing Chain, 22RE
  17. Tread design or tire size..power/gas culprit?
  18. Another Rear Window Prob
  19. ADD to Manual Swap....not hubs...
  20. Bad torsion bars?
  21. A340H Tranny? Where to buy rebuilt and is R&R DIY?
  22. What is timming on 22r EFI ?
  23. need code help here guys....91 2wd 22re
  24. What size tires are you running? (IFS Only)
  25. Ideal crossover for V6 w/ Downey headers, 1" BL and BudBuilt Skid & Crossmember?
  26. 1988 4 runner NEW oil leak
  27. ca you help me
  28. So my wheels get stolen.....
  29. Cracked (in half) Bellhousing
  30. Strange noise?
  31. Stupid Tranny!
  32. Toyota Tech Needed
  33. How can I recondition the shift boot?
  34. Did they put 4 cylinder engines in the 2nd generation 4runners?
  35. PS(power steering) question?
  36. Painted my alloy rims black! (Pics)
  37. Is replacing front 3rd member any more difficult than axle removal?
  38. Bench bleed question
  39. Absolutely un-funny...Water pump leaking again!!
  40. Rough Idle
  41. Source for 1st generation rear end bumper caps?
  42. 87 4Runner Mild DD- How much work to fit?
  43. New gaskets all over, but what should I also replace?
  44. 96 wheels on a 91 4Runner
  45. thoughts on maf conversion
  46. My brake bleeding method
  47. Engine Help-3.0,3vze, etc
  48. 4 pinion 8" axle interchangeable with 2 pinion 8"? Help quickly!
  49. CEL Trouble code...what does this mean?
  50. Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4?
  51. Engine Fault code 25..need help
  52. Vacuum hoses and whatnot
  53. Balljoint spacer tip trick
  54. Cant get 22re to base timing
  55. 90 v6 running rich, rough idle, stalling...HELP!
  56. 4runner needs more power
  57. Fuel delivery problems
  58. 88 4 cyl. vs 95 6 cyl.
  59. Marlin Crawler T-Case gears and V6 T-case
  60. Lubrication of Steering Knuckle and Chassis
  61. 2WD steering (I have looked through first)
  62. Buckets in a Reg Cab
  63. Warning Buzzer Location
  64. New dashpot and super high idle
  65. Mounting tube on rack..need ideas.
  66. Pitman arm
  67. sas wheel spacer question
  68. Sr5 85
  69. '91 PU w/ 350 V8 - $5,500. Good Deal?
  70. header for auto trans column shift 22R
  71. Truck fuel pump replacement
  72. How hard to change out heater fan switch?
  73. Correct idle RPM for 22RE
  74. 22RE High Cold Idle
  75. 22ret
  76. Building a 91 2wd
  77. clogged catilytic converter
  78. manual hubs wont fit on 4runner HELP!
  79. Am I missing some bolts/plugs here? Transmission
  80. 22re head gasket
  81. Life expectancy of 3vze oil pump
  82. Hose Help Please
  83. Short vs Long side LC coils???
  84. 3VZE misfiring/stalling/bucking issue
  85. E-brake cable snapped on 94 SR5 PU
  86. What coolant do you use in your 3.0?
  87. Exactly how can I tell if my cv is broken
  88. Weird tire rubbing noise?
  89. SwayBar Clunk
  90. I'm new to the forums
  91. Steering wheel play
  92. 22re vaccum line size
  93. New MINT '90 4runner in garage, Qs on aftermarket steering wheel/rear lift spacer!?
  94. burnt valve symptoms
  95. KS testing? and fuel pressure regulator?
  96. Transmission question
  97. Downey flared fenders
  98. Are my torsion bars worn out?
  99. What is this box and...?
  100. Swapping in bucket seats
  101. Temp Sending units
  102. turbo questions
  103. ECU compatability question
  104. 3.0 water pump revisited for the 3rd time in 3 months
  105. Persistant Leak around Thermostat housing
  106. Anybody do this: H1 Kit for Toyota 4x4s. . .
  107. Pinion angle adjustment with 1" drivetrain lift
  108. Throw-out and pilot bearings
  109. Upgrade Dash/Interior 86 4Runner -> 9x 4Runner?
  110. no overdive
  111. Throttle Position Sensor
  112. And so it begins...Auto to Manual transmission swap on 93 3.0 4 runner
  113. Master bushing kit for an '89 4Runner?
  114. Can't find my starter relay...(1st Gen (88)
  115. Looking for a good manual or link to adjust valves on 3.0
  116. 200k service ?
  117. Regearing for 33's
  118. Is this the right timing chain kit?
  119. Will a malfunctioning EGR cause a strong gas smell
  120. BudBuilt Skid/Belly Pan Group Buy!
  121. 95 4Runner
  122. 94 4runner front axle tube seal
  123. Porportioning Valve Removal???
  124. Oregon Engine Rebuilders Inc.
  125. Need opinions on Mufflers
  126. Quiet as a mouse when cold, loud clattering when hot
  127. Exhaust smells like rotten eggs!?
  128. Moving the Clock.
  129. 150K Engine Checkup
  130. inclinometer mounting suggestions
  131. IFS travel
  132. Found a 4runner in pasture
  133. Wtb: 89' V6 4x4 Auto Sr5 Pickup Speedometer Cluster
  134. E-85 conversion. What's needed?
  135. Clutch leak/Dark clutch fluid
  136. Weird Starting issue
  137. Front end noise...help, thanks
  138. mpg for 22-re rigs
  139. soft top options
  140. quick speaker size question
  141. seat belt rewind...
  142. what else do i need for header swap?
  143. Reman'd engine q's...
  144. Starting problems,1992 truck
  145. ? about a 94 4runner with a 3.0 with high miles
  146. 87 turbo problems
  147. cleaning throttle body
  148. Tire Carrier Bracing
  149. 2nd gen upgrades...?
  150. problem starting my 94 4runner
  151. Switching over to Synthetic oil+manual trans.
  152. 91 4runner New Tranny Worth it or Junk it?
  153. Door handle/lock problems.
  154. frame/cab swap?
  155. 94 toyota 4runner rear window problems
  156. 1987 22R Black Smoke and Backfires
  157. Auto Trans Question
  158. 3.0 5 spd mpg
  159. What controls the tach on a 95 runner??
  160. Checking codes on an 89?
  161. reciever hitch?
  162. No 3.0 altitude compensation? what a joke
  163. man trans movement?
  164. Aisin junkyard hubs
  165. Where does this wire go?
  166. New paint on my 94 4x4 Truck
  167. 3.0 Head Improvements?
  168. Transmission removal
  169. 22re stroker
  170. Ethanol and the 22re?
  171. Part number for A/C pressure switch?
  172. Should I buy this 4Runner
  173. Oil pan drain plug ... Gone
  174. Gas on the trail
  175. Need help removing guage cluster
  176. Anyone mount a Hi-Lift to factory wheel carrier?
  177. 3.0 Valve shims ?
  178. code 26
  179. help w/ front wheel caliper removal w/ ABS
  180. smoke, gurgle, what the...
  181. door swapping
  182. help my windows and lock don't work.
  183. Friday was a busy day
  184. Rear Antilock light on and off!
  185. Leaf springs; replace or re-arch?
  186. My Gosh, my 3.0 was impossible to burp today!
  187. Engines....what To Do?!?!?
  188. '90 4runner diffrential
  189. problem with driveshaft bolts
  190. Nasty Vibration
  191. Broke my rear driveshaft
  192. Need to lower my truck back to original height
  193. on again off again check engine light
  194. 22Re number of crank pulleys
  195. Tach swap info for '89-'95 P/u
  196. vote on my latest mod (and see old ones) <PICS>
  197. CV Boot
  198. 94 PU- Blinker wont stay on
  199. new idea maybe? smoke stacks.
  200. mounting 3vze to engine stand
  201. oil pan gasket replacement
  202. Ignition Noise Filter
  203. Buying a rear drive shaft from car-parts.com
  204. Can an exhust leak affect preformance?
  205. AFM Mod: Rich or Lean ??
  206. 86 R151F Tranny gear problems
  207. Pre-cranking front torsion bars on a 94 runner 3.0
  208. 4 cyl to v6 front third member?
  209. 1st gen cruise control question
  210. Service manual for 1992 toyota pickup???
  211. Tailgate Handle -- FYI
  212. Rebuild to start soon
  213. Rebuilt 3.0 orientengines?
  214. The mysterious intake side
  215. 94 Rnnr rr windw problms. HELP
  216. 1st Gen 4runnr Spare tire mount??<on tail gate?
  217. '87 4Runner SR5 brake suggestions
  218. loss in power, wont accelerate 93 3.0 5spd
  219. How much lift to level rear (PIC)
  220. 1991 4 runner 3.0 Motor mount
  221. Still havnt fixed the tranny problem!
  222. How much lift w/ deaver triple pack?
  223. Bedliner in the cab
  224. 89 22RE ticking
  225. The mod snowballeffect. Poly Body mounts
  226. VSV and the FPU
  227. Coolant leak
  228. $800 sound about right for a 22re fuel pump?
  229. runs rough when warm 3.0
  230. Proper water pump gasket material/installation?
  231. Finally figured out how to hook up my altimeter!! But where to find harness?
  232. Torque specs on cv shaft bolts
  233. Fj 40 axles in my 1st gen.
  234. Where to get an OEM Air Intake Hose?
  235. 35's with 7" lift. Anyone had damage?
  236. Will this ARB bumper fit my 2nd gen
  237. Body Lift = Broken Mounts
  238. 89 4Runner coming out of the pole barn!! Whoo hooo!!! Pic!!
  239. 22R-E Build up under Valve Covers (PICS)
  240. 3.0 Valve Cover Gaskets
  241. How rare are 4.88 factory gears?
  242. Knock sensor CONNECTOR location?
  243. OME Rear leaf springs
  244. Engine Knock Diagnosis #2
  245. Speed Sendor location?
  246. will parts from a 92 4R fit a 90?
  247. Brake Light
  248. check engine light
  249. What Next ? Headers or Gears with Locker?
  250. 94 Pickup Unknown Error Code
